Engine oil leak: VTEC solenoid?
Hi, I have a 2005 Si with 78k on it. Has an oil leak that starts pretty high up so I put on a new valve cover gasket first. It still leaks, looks like the VTEC solenoid or gasket. My question is does the solenoid itself leak or it usually just the gasket/o-ring where it mounts to the head?
Can the valve cover leak even when replaced, are there any tricks to getting a good seal other than a dab of RTV in the corners?
Thanks
Thanks
eurochoi
12
09-13-2012 07:16 AM
Master23
06-05-2006 07:34 PM
