Door Lock Problems RSX Type S
So today i removed my door panels to fix the interior door handle's, because they were not opening from inside the car. Only the exterior door handles would release the latch. After finding that both cables inside the door panel had fallen out of there cable socket holder. I had put them back in place as well as added a zip-tie to the cable to fix it to the interior door panel. I then tested both doors pulling both interior and exterior door handles. It worked great. I then used the the power locks with one door open to lock the doors. Pushed the remaining door lock manually that was left open and closed the doors. When i came back i used my key to manually open the door and the plastic lock stem appeared to pop up like normal with no hesitation, but the door did not open. I had to take out my quarter window and slide my self through only to find out that the interior door handles don't work either. My power locks sound to be working but the latch will not open. Any Idea's or help will be appreciated???
