Check Engine code 41 quick question please help!
Ok I got a check engine light, I just got the car bought it from a friend, anyways my friend told me he lost the gas cap when he got gas he forgot to put it on and thats when the check engine came on, it has a gas cap now, but just one that he had in his garage, the code that I got when I tested was 41 which is air fuel ratio, so I want to know if I buy the stock or oem gas cap will the check engine go away? I reset the ecu once to see how long it would take to turn back on it was about 130ish miles. So please help if you can thanks in advance.
Re: Check Engine code 41 quick question please help!
Well does anybody know if this code is the primary o2 sensor, or is it the secondary one? im getting a new gas cap today then Im going to reset the cel if it comes back then I guess it is the o2 sensor.
Ok I forgot my uncle had a code reader so I got it scan for codes and got one which was P0134 which is the primary o2 sensor correct? the one before that cat? Let me know thanks
So Can I just replace the sensor to fix it? Because I noticed the cel will come on after awhile it goes off, so im thinking the sensor is going out or maybe the wiring. Anybody have any experience with this?
