car starts few second. shut off instantly.
have a ep3.
car runs for about 2-3 second and dies instantly. does not sputter and not gradual.
getting fuel pressure.
checked fuse
checked main relay
immobilizer light not on
checked fuse
checked main relay
Re: car starts few second. shut off instantly.
By the way, fuel injectors are electrical not just mechanical, though I don't know why you would be entirely focused on electrical at this point.
It's your timing. pull the timing belt covers and check. More than likely it's off a tooth or two. So check your tensioner while you're at it.
Based on the list of things that check out fine, I don't see how the ECU could be the problem. Did he check the mechanical timing?
No he's not. He's just trying to rule it out. He said then he can check the wiring. I'll bring it up with him. btw problem started with the crankshaft seal. I was getting it replaced due to oil leak. I was watching what he was doing and all he did was remove the Serpentine belt and crankshaft bolt. I did replace the crankshaft sensor thinking it was that.
