Camshaft sensor ques.
Old 04-11-2008, 02:46 PM
I Am White's Avatar
Default Camshaft sensor ques.
I am showing the engine light. the code is P0341, Camshaft Position Sensor; Bank 1 ckt range/perf.
Is this just a 10 dollar piece i buy and replace? I all ready know where it is, and I'm assuming that bank1 is the one closest to the front of the car (intake cam). Is it just a bad sensor or is it telling me something is wrong woth my cam positioning? how do i approach this specific sensor problem? What exactly does this sensor do for the car? Just for my knowledge. thanx guys
Modified by I Am White at 4:31 PM 4/11/2008
Modified by I Am White at 3:04 AM 4/12/2008
Old 04-15-2008, 09:39 AM
I Am White's Avatar
Default Re: Camshaft sensor ques. (I Am White)
no one has any idea abou tthis piece?
Old 05-01-2010, 03:12 PM
thrty8street's Avatar
bump
Old 05-01-2010, 05:09 PM
square_1's Avatar
A check engine code is just the car telling you what it THINKS is wrong with itself. It could be something else that makes the car think the cam sensor is bad. Do some research and homework. If you don't know what a camshaft position sensor does, read up on it. We can't diagnose your car from X,000 miles away. I also guarantee it isn't a $10 part. Sorry if this is blunt but you should do some searching and reading.
Old 05-05-2010, 09:41 AM
I have tried searching. This is how I cam about this thread. I am having a hard time finding more information on this problem. If you know of any info or can lead me in the right direction as to where to find it please do.
Old 05-06-2010, 07:11 AM
bump
Old 05-06-2010, 02:35 PM
blackKready's Avatar
this coule be 2 different problems. either the sensor in question itself is bad. which of course is an easy fix. OR , lol. your timing is now off due to your tensioner failing slowly and timing chain stretching. what i recommend for you , is to take the 3 10mm bolts holding the inspection cover on that hides the tensioner , and inspect to see how far out the piston is.
thats your first step right now.
kissifur
06-20-2014 12:45 PM
efyou999
05-24-2012 12:21 AM
99d-series
05-01-2009 08:56 AM
HATCHFREEK
03-19-2003 10:32 AM
Quick Reply: Camshaft sensor ques.
