Removing trunk liner 2005 honda civic si
I can't remove the Screw/Clip for my trunk liner the screw is broken or stuck. How can I remove it without breaking? I need to replace my tail light bulb.
Re: Removing trunk liner 2005 honda civic si
this is one of the ones with a center screw? I have good luck putting a small pry tool under the head and turning out the middle portion. failing that, just push the middle part right through (instead of trying to pull it out, just force it in). you will break the screw, but it sounds like it's already pooched anyways. and dealers still carry replacements.
