BENEN TOW HOOK HELP! - Honda-Tech
Old 01-08-2008, 10:26 PM   #1
johnclaunch's Avatar
Default BENEN TOW HOOK HELP!
I received my Benen tow hook set and the rear hook is way too short to clear the rear bumper. Does anyone have any insight and pics of one installed on an EP3? The seller claims that they are all universal fit so if I can't get it to work I am out the money I spend which sucks. Any help is appreciated.
johnclaunch is offline   Reply With Quote
Old 01-09-2008, 12:07 AM   #2
NTCustoms's Avatar
it doesn't have to stick out that much....and it doesn't have to stick out straight either
NTCustoms is offline   Reply With Quote
Old 01-09-2008, 04:34 AM   #3
Default Re: (NTCustoms)
I would like it to extend out clear of my bumper so that if I need the car towed, everything stays plenty clear of the bumper. If I did bolt it on how it fits, it would sit maybe 3 inches of the ground and scrape on EVERYTHING. It would mount pointed downward an as I said, would not even reach to the edge of the bumper (if I could even get the blot holes to line up at that angle with the factory hook which I don't think they will). I want it to clear the bumper, be away from the car, and be usable. this set is obviously not going to work, so any suggestions of other brands to try?
Old 01-10-2008, 02:21 PM   #4
WhiteOnRice's Avatar
Take some pics (tow hook and rear of car) and maybe we could give install suggestions.
WhiteOnRice is offline   Reply With Quote
Old 01-11-2008, 07:13 PM   #5
Default Re: (WhiteOnRice)
I'll post some up soon.
Old 01-20-2008, 02:20 PM   #6
Okay, here are some pics:
Existing tow hook:
The Benen hook:
Old 01-20-2008, 03:05 PM   #7
Official H-T Cake Maker
C4st0r_Tr0y's Avatar
Default Re: (johnclaunch)
Im pretty sure with the ep's rear bumper you have to cut it slightly for it to fit up in there.. idk something like that
C4st0r_Tr0y is offline   Reply With Quote
Old 01-20-2008, 03:38 PM   #8
Default Re: (C4st0r_Tr0y)
I am not going to cut the bumper. If I cannot get these hooks to install correctly, I will just shop for longer ones (I have seen them). Maybe J's Racing?
Old 01-20-2008, 04:06 PM   #9
Do you have an aftermarket rear bumper?
My mistake you dont have to cut the bumper to fit it on the oem bumpers..pic from ephatch:
Old 01-20-2008, 07:31 PM   #10
In that pic it looks like the bumper is pushed up a bit to get it to fit. Anyway, yes, I have the factory bumper with the HFP kit. The HFP kit is what renders my factory tow hook useless (without damaging the bumper by using it). If I didn't have the HFP kit, there would be no reason to use a tow hook, since the factory one would suffice. The whole reason I am trying to install a tow hook is so that my car can be towed without damage to the bumper. (In the install instructions for the HFP kit, it directs to remove the bumper prior to towing, which could be impractical in most situations.) Basically I guess the new question is for what brand out there that one has personal experience with, will work for my application (long enough to clear the bumper and lip) and has a matching front hook?
Old 01-20-2008, 10:07 PM   #11
NTCustoms's Avatar
in your pictures you have it back too far. the original tow hoook should be in between the two holes
Old 01-21-2008, 12:48 AM   #12
Quote:
Good looking out, i didnt even notice that
Old 01-21-2008, 01:57 AM   #13
I think you need to look for a different tow hook.
Old 01-21-2008, 10:56 PM   #14
Quote:
Looks like it. Hey, anyone wanna buy a Benen set?
Old 01-21-2008, 11:21 PM   #15
mormonboy's Avatar
wow, a thread on how to install a tow hook? wtf.
mormonboy is offline   Reply With Quote
Old 01-22-2008, 11:10 AM   #16
Quote:
You should have no problem in the eg/ek forum.
Old 01-22-2008, 10:05 PM   #17
I actually got it installed. I pushed it up against the lip as much as I could but it still angles down a bit. I drove it to and from work today with no scrapes. It sits about 4.5 inches off of the ground at the lowest point. I had to use longer bolts to get it to bolt on (I used the bolts for the front hook), so now I have to buy some new bolts for the front and that one goes on next week (I have to remove the bumper and drill into the actual metal bumper, so I'll have fun with that I'm sure. I am also planning to paint the headlights black at that same time since I will already have the bumper off.
Old 02-02-2010, 09:25 AM   #18
Default Re: BENEN TOW HOOK HELP!
I jus bought Pink tow hooks!
BucJoy is offline   Reply With Quote
Old 02-02-2010, 09:45 AM   #19
Function > Form
josh's ep3's Avatar
Umm.... rock on?
josh's ep3 is offline   Reply With Quote
Old 02-02-2010, 10:01 AM   #20
mustclime's Avatar
I use a strap on the front and my trailor hitch on the rear for track days where they are required....
http://www.ioportracing.com/Merchant...egory_Code=TOW
the strap is mounted where the plate mounts to the steel part of your bumper.......hooks and straps should be able to take the load of pulling the car out of the mud.......
mustclime is offline   Reply With Quote
Old 02-02-2010, 10:05 AM   #21
Function > Form
josh's ep3's Avatar
Yeah, those Benen's are purely for looks. I don't think that dinky peice of aluminum is going to hold your car when being towed.
Old 02-02-2010, 10:35 AM   #22
square_1's Avatar
Would it be that hard to just cut and weld some pieces of steel into the shape and design you want? It seems like if you bought some 1/4" thick steel and welded up your own design, sanded it down really nice and had it painted or power coated it would look sick.
I guess it wouldn't be "JDM" though.
square_1 is offline   Reply With Quote
Old 02-02-2010, 10:47 AM   #23
turboteg2nv's Avatar
Quote:
Quote:
Originally Posted by josh's ep3 View Post
Umm.... rock on?
bwhahaha.
turboteg2nv is offline   Reply With Quote
Old 02-04-2010, 10:22 AM   #24
Jewls's Avatar
heres mine.....
and this is the front one.
Jewls is offline   Reply With Quote
WTB: Benen Rear Tow Hook Gold blackfity Southern California (Sales) 8 05-22-2009 01:13 AM
WTB: BENEN BARS myronwong Want to Buy 7 03-29-2007 12:01 AM
WTB- Benen rear tow hook... red_crx Want to Buy 3 02-20-2007 02:00 PM
Benen Tow Hook Set. xtremecivichb For Sale 16 10-20-2006 08:08 AM
WTB: BENEN rear tow hook! tyflip2 Want to Buy 11 01-09-2004 08:28 PM
Tags
benen, blueprints, ek, front, honda, hook, hooks, install, installation, installed, prelude, rear, rsx, set, tow, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
