Anyone have the Rsx Type S Gauge cluster Pinouts? - Honda-Tech
Old 09-26-2004, 07:19 PM   #1
KustomCrx's Avatar
Default Anyone have the Rsx Type S Gauge cluster Pinouts?
Im looking for the pinouts for the gauge cluster for rsx type s. if you have a site or something to help me, please let me know.
KustomCrx is offline   Reply With Quote
Old 09-26-2004, 07:33 PM   #2
Ocelaris's Avatar
Default Re: Anyone have the Rsx Type S Gauge cluster Pinouts? (KustomCrx)
There's a guy on ephatch Bemunger (probably name wrong) who has swapped a RSX gauge cluster into an EP3... so he knows all the pinouts and everything... just search for rsx cluster or gauge on ephatch...
Ocelaris is offline   Reply With Quote
Old 09-27-2004, 04:43 PM   #3
Modern91Hatch's Avatar
I'm working on the same project too. I've downloaded the RSX Service Manual at:
http://johnscustompcs.com/03rsx-s/HELMS_RSX.pdf
I'm working on Bookmarking all the Sections and sub-sections. I'll post soon. The some of the cluster info begins around page: 1211
Pin out Info:
-B is the smaller connector (on the left looking at the back)
-Pinout for B goes 1(top Left) - 9 (Top right) | 10 (Bottom Left) - 18 (Bottom right)
Pin for connector A is the same + 4)
Most LEDs should be pulled to ground to light, Some, however, must have +12v to make them light.
Here's what I got so far:
CONNECTOR A:
A3 LED - Security Indicator
A4 +12v for Immobilizer
A5 LED- High Beam
A6 +12v for High Beam LED
A7 LED - Left turnsignal (must apply +12v)
A8 LED - Cruise Control
A10 LED - Immobilizer
A13 Dash Lights Output (I believe the4 CPU control brightness)
A14 ABS Control Unit Inuput
A15 LED - SRS Unit (must apply +12v)
A21 LED - Oil Pressure
A22 LED - Check Engine Light
CONNECTOR B:
B6 +12v (On all the time)
B7 +12v (Ingition switch-on)
B8 LED:Side Airbag Off
B9 LED:Turn Signal (must apply +12v)
B13 Connects to Multiplex-which controls many inputs
B14 Tachometer
B15 VSS(Vehicle Speed Sensor)
B16 Fuel Gauge
B17 GROUND 1
B18 GROUND 2
This is all I have so far. I believe you also need the Multiplex Unit that connects to Pin B13. The think Multiplex has several inputs:
-Coolant Temp
-Seat Belt Warning LED
-Break LED
-Door Open Indicator
-Charging System LED
I don't know if you can control these with other Pins on the cluster. I'm wokring on it now. I'm putting this RSX cluster in my 91 Civic Si. I think it will fit, but it will be a tight one. If anyone has more infomation on doing this cluster install, please let us know! Also if anyone has info on Putting a VSS on a Cable Tranny. I think... it's a direct fit.
Current Setup:
91 Civic Si
JDM DOHC ZC
Intake + Header
Stock Exhaust
Soon:
JDM B16A2
OBD0-OBD1 Setup
RSX Cluster
Modern91Hatch is offline   Reply With Quote
Old 03-06-2005, 08:27 PM   #4
EK9Greg's Avatar
bump
EK9Greg is offline   Reply With Quote
Old 02-04-2017, 08:12 PM   #5
Quote:
Alfredo Medina is offline   Reply With Quote
pinout cluster honda civic type s hackbest Honda Civic (2006 - 2015) 4 02-04-2017 08:02 PM
S2k cluster FS. Lowball me! cvcrcr99 Northeast (Sales) 8 07-14-2009 08:31 AM
Online Service manual Zatzy Acura Integra Type-R 18 06-29-2005 06:56 AM
Anyone have an EG gauge cluster pinout? JDMotive Hybrid / Engine Swaps 5 12-17-2004 10:09 PM
Anyone have cluster and underdash plug pinouts for a '94 cx hatch? JDMotive Honda Civic / Del Sol (1992 - 2000) 0 12-16-2004 12:33 AM
Tags
acura, beam, cluster, connectors, dc5, ek, gauge, high, led, multiplex, pinout, pinouts, rsx, temp, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
