2003 Honda Civic Si Cruise Control Problem - Honda-Tech
Old 03-21-2011, 11:46 AM   #1
Icon2 2003 Honda Civic Si Cruise Control Problem
Hello,
I am having some trouble with the cruise control in my 2003 Civic Si. All of the indicator lights work on the dash. When I activate the cruise control button that is on the left of the steering wheel, I am able to activate the cruise control button on the steering wheel and the light on the dash illuminates as if the cruise control is indeed engaged. However, after letting off the gas pedal, it is immediately apparent that the cruise control has definitely not engaged, as the car decelerates.
Helpful details:
The horn works, the headlights work fine, all indicator lights work as if nothing is wrong.
I hope someone can help me I am planning a road trip to California, from Colorado, this summer for a wedding, and it would really suck to have to drive the whole way without the help of cruise control!
civicvixen is offline   Reply With Quote
Old 03-21-2011, 12:12 PM   #2
Default Re: 2003 Honda Civic Si Cruise Control Problem
Sounds Like it is electronic
cocktails is offline   Reply With Quote
Old 03-21-2011, 12:44 PM   #3
cruis control cable?
space_eyes is offline   Reply With Quote
Old 03-21-2011, 02:46 PM   #4
rjmq06's Avatar
ummm when activate it by pressing on the steering wheel make sure you press the SET button when youre on the desired speed, its one the bottom one
rjmq06 is offline   Reply With Quote
Old 03-21-2011, 08:54 PM   #5
H0ndas g0 Vr00m's Avatar
Check the Cable that goes to the Throttle Body. If you beat on the car, or make a couple fast pulls then the cable can come loose off of the place it needs to be on the Throttle Body. Mine did it and its about a 10 minute fix.
H0ndas g0 Vr00m is offline   Reply With Quote
Old 03-22-2011, 06:47 AM   #6
Quote:
WOW... facetious comments are not necessary.... I am a scientist, I do think I have tried the obvious....
To all of those that have put helpful answers, thank you! I really do appreciate the help!
Old 03-22-2011, 06:59 AM   #7
Could please explain to me where it is located?
Old 03-22-2011, 07:58 AM   #8
El Presidente
DaveSi677's Avatar
Mad scientist what he was trying to do is called troubleshooting... you know when you eliminate all possibilities one by one? You should know about that you use it on a day to day basis at the lab right?
By reading your first post I just want to state the obvious that you never mentioned you set your speed correctly...
Have you checked the fuse under the steering column?
DaveSi677 is offline   Reply With Quote
Old 03-22-2011, 08:29 AM   #9
cloumep3's Avatar
chillio bro, I wouldn't take it the wrong way...
cloumep3 is offline   Reply With Quote
Old 03-22-2011, 12:15 PM   #10
Asking if I properly know how to use cruise control? To me, it sounds like the person is being a smart ***! Of course I know how to work the SET button. I did mention all of the obvious in my first post. I ensured all buttons necessary for cruise control to engage were operational.
Here is my theory... It could be one of the following...
-Loose hose
-Bad fuse(s)
-Stuck/broken Clutch Actuator (I know the brake actuator is operational because the light on the dash turns off once the brake pedal is tapped)
Any other theories out there/helpful comments?
Seeing as you mentioned that I am an educated individual and not a complete idiot, lets assume I have tried the obvious... I have done tons of reading... but there are so many things that could go wrong... All lights/buttons are operational, so it makes me believe that it probably isn't a fuse...
I will put a few theories to the test and will keep you guys updated.
Old 03-22-2011, 05:39 PM   #11
rjmq06's Avatar
lol im not being a smart *** buddy just trying to help
were trying to figure it out one by one
and i said desired speed
NVM good luck with that bro looks like youve already have the list of problems
Old 03-22-2011, 05:44 PM   #12
square_1's Avatar
I don't know much about EP3 cruise systems but if it is vacuum actuated (like many are) you can grab a vacuum gauge and find out if you have a leak. Those are about 25 bucks at an auto parts store.
Also maybe just grab a clutch switch from Honda, I doubt it is more than $30 bucks?
square_1 is offline   Reply With Quote
Old 03-23-2011, 12:37 PM   #13
So I tested the clutch switch yesterday and it is in working order. Still need to pop the hood and have a look at the hose! The vacuum gauge is a great idea! Thanks!
Cruise control only works ocassionally Nealva Honda Accord (1990 - 2002) 1 10-12-2016 05:23 PM
cruise control 2000 civic Joshboom2488 Honda Civic / Del Sol (1992 - 2000) 2 06-08-2015 08:42 AM
2003 accord cruise control meals Honda Accord & Crosstour (2003 - Current) 5 05-08-2014 08:21 AM
1995 Civic Ex cruise control speedy223 Honda Civic / Del Sol (1992 - 2000) 1 05-02-2013 03:54 PM
Cruise control issue advanced diagnostic help please... accord99power Honda Accord (1990 - 2002) 3 03-18-2013 06:12 PM
Tags
2002, 2003, 93, civic, control, cruise, crv, doesnt, electronic, fuse, honda, problem, problems, si, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
