2003 EP3 wheelspin knock
Re: 2003 EP3 wheelspin knock
You'll get some better help if you post in the appropriate forum.
https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/
i would want to figure out why it's loosing traction before i figure what's making that noise... but yea, speedoo is right. post in the correct forum and you'll get some better help.
Welcome to Honda-tech, look like they moved your thread to the EP3 forum.
Check your motor mounts and make sure they aren't torn. Also check your tire pressure, make sure its 32-35psi on all 4 wheels (depending on your wheel/tire setup).
How many miles are on your car?
Also - if you start to have wheel spin, try to modulate the throttle so you aren't wheel-hopping all over the place. It's bad for the transmission and a slew of other parts that like to break. If you're getting wheel spin from a dig then learn to launch better.
Thanks for the feedback, should have worded my thread better,makes me sound like boy racer!.Had my car 6 yrs mint condition,only just got 50k on clock.Only spinning when pulling out quick!
It's probably a combination of wheel hop and bad mounts. The wheel hop makes mounts go bad, bad mounts makes the wheel hop worse, then you get the banging noise...
CoupeKidz13
09-02-2011 11:20 PM
Clay@tirerack
11-15-2005 08:53 PM
