2002 Si, engine cuts out around 4000 RPM - Page 2 - Honda-Tech
Old 03-25-2015, 12:04 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Old 02-21-2011, 09:21 PM   #26
El Presidente
DaveSi677's Avatar
Default Re: 2002 Si, engine cuts out around 4000 RPM
Ya I got an ELD cel and in Canada the part is 200$... so I had to order it from the US cost me 50$ with shipping and got rid of that headache!
DaveSi677 is offline   Reply With Quote
Old 02-22-2011, 02:53 PM   #27
ShamArtist's Avatar
Thanks for all the help guys. Ordered the ELD last night for $20 and the VTEC Spool Valve for $75 today. I'll let you know how it goes when I get parts and install them.
ShamArtist is offline   Reply With Quote
Old 02-22-2011, 05:00 PM   #28
El Presidente
DaveSi677's Avatar
Nice prices on the parts... keep us posted!
Old 02-26-2011, 09:11 AM   #29
ShamArtist's Avatar
Well my OBD2 to USB cable came in along with my ELD relay. Scanned with PCMscan and all the same codes that autozone found came up. Was just making sure it worked. Anyway I replaced the ELD and my p1298 code is gone! Going to do the o2 when the snow melts. Still waiting on my VTEC solenoid. Hopefully it comes today.
Old 04-10-2011, 10:32 AM   #30
campbuds's Avatar
So... how did it all turn out with this? My car loses power randomly starting last night and today I was able to get the CEL. Pulled the code and it is a P2646
I would like to know if you fixed that code and what you did. I need to get this fixed before it causes other problems.
campbuds is offline   Reply With Quote
Old 04-10-2011, 03:16 PM   #31
campbuds's Avatar
NVM... I was just low on oil
Old 03-04-2012, 05:27 PM   #32
hi mike, i have the same problem on my 2003 accord, i changed the oil pressure switch but still the check engine comes on and off intermittently, could you please tell me what happened to your problem finally? changing the spool valve solved the problem?
thanks
Goldasteh is offline   Reply With Quote
Old 09-28-2013, 05:13 PM   #33
Quote:
Originally Posted by Targa250R View Post
An oxygen sensor code won't cause a low rev limit. I can guarantee you that there are more codes stored in the ECM - likely a P1259, P2646, or P2647. You obviously haven't checked codes since the rev limit problem has occurred - this is why it's stupid to drive around with the Check Egnine light on constantly, especially when you know it's an easy and inexpensive repair like an oxygen sensor.
If the oil level is full, and you have a code P2646 or P2647, replace the VTEC oil pressure switch on the VTEC spool valve. If you have a code P1259, replace the entire VTEC spool valve.
If you have any other codes, post them here.
Hey targa I'm having the same problem as this guy and I got code p1259 and you had said replace the whole spool valve and I was wondering if I have that code and is doing the same thing do I have to replace the entire vtec solenoid spool valve? Is the whole unit bad if I get that code? P1259 vtec malfunction code. Thxs for your help, much appreciated!
cwatson42785 is offline   Reply With Quote
Old 04-30-2016, 04:31 PM   #34
I'm having the same issue. It rained hard today and I made sure not to go to deep but I'm suspecting it has to do with vetch since it kicks in at 4K I need to solve this fast
Chris Cruver is offline   Reply With Quote
Old 02-27-2017, 08:40 PM   #35
Icon7 Re: 2002 Si, engine cuts out around 4000 RPM
2002 Honda Civic 7th Gen Model ES 1.7 litre manual.
My problem was the car engine cut out randomly on extremely hot days with engine light illuminated on dash.
After 2 minutes it would start normally with no engine light but then cut out again after a few minutes.
Eventually after much research I traced it to a faulty TDC Sensor (Camshaft Sensor) which was failing due to heat.
I replaced the sensor and have not had the problem again for 10000 kms.
Hope this helps someone as it was a very frustrating intermittent fault.
Sinkenken is offline   Reply With Quote
1999 accord 2.3 vtec stutters @ 4,000rpm amaidendevil Honda Accord (1990 - 2002) 4 05-16-2016 01:24 PM
VTEC solenoid going out? (EP3) EP3PO Acura RSX DC5 & Honda Civic EP3 0 04-30-2016 07:22 AM
P1259 driving me nuts macmilla Honda Accord (1990 - 2002) 1 10-14-2015 11:03 AM
car cuts of at 3500-4000 hatchyboy89 Forced Induction 6 04-19-2006 06:02 PM
93 Honda Del Sol w/ turbo Cuts out when warmed up 93hondadelsol8psiturbo Honda Civic / Del Sol (1992 - 2000) 1 04-30-2005 04:56 PM
Tags
1990, 2002, 4000, 4k, accord, blinks, check, civic, cut, engine, honda, light, o2, replacing, rev, reving, rpm, rpms, sensor, si
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
