wut's the different between the engines...
Old 11-01-2003, 04:49 PM
kool168's Avatar
Default wut's the different between the engines...
wut's the different between the engines JDM B18C 96 spec and JDM B18C 98 spec?
the engine model number for JDM B18C 96 spec is B18C3, but the B18C 98 spec is B18C, so am i correct or they are the same model number appear on the engine?
Old 11-01-2003, 11:00 PM
vladd's Avatar
Default Re: wut's the different between the engines... (kool168)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kool168 &raquo;</TD></TR><TR><TD CLASS="quote">
the engine model number for JDM B18C 96 spec is B18C3</TD></TR></TABLE>
not its not. jdm engines dont have the last number.
Old 11-01-2003, 11:50 PM
kool168's Avatar
Default Re: wut's the different between the engines... (civicdxtyper)
so both of them have the same model number...
then how can we identify which one is 98 spec?
coz i just bought an engine, and the seller said it's year 2000 engine, but my friend said it is 96 spec...
96 and 2000 is 4 years different and
i am kinda worry about this, since if it is really 96 spec, then the price i bought this engine would be too high...
Old 11-02-2003, 01:27 AM
Nameless RB26's Avatar
If it came with an ECU... give us the code for it and we can tell you what year the ecu is.
If it's a 2 piece header, then it was likely produced between 96-97. If it's the famous one piece header then you've probably got the engine you want.
There should also be a production date on the head, above the header. Something like 9/6, 9/7, 9/8, etc.
None of these will give you 100% verification, but they will help you out.
And no, Japan never had a B18c3 as far as I know. I know they were made, but they were not the 1996 JDM ITR engine like some websites like to think. Someone prove me wrong....
Old 11-02-2003, 01:46 AM
kool168's Avatar
Default Re: wut's the different between the engines... (Nameless EJ6)
it's 2 pieces header, the 4-2-1 one...
then it is mostly 96 spec engine...
this is sad... why this world always filled up with such these business people always telling lie to cheat people money...
Old 11-02-2003, 01:47 AM
kool168's Avatar
so the 96 spec engine is weaker than the 98 spec, is that true?
Old 11-02-2003, 02:43 AM
MiraiZ's Avatar
if its a 96 spec, then the power rating is slightly different:
-98+ spec have more agressive cam profiles (same as CTR cams)
-4-1 one piece header
-tranny has tighter ratio.
- all this will produce slightly more torque
Old 11-02-2003, 04:19 PM
That Dood's Avatar
does it look 3 years old or 7?
machgo5go's Avatar
Vol 1 USDM Best Motoring : Type R Legend have some highlites on their differences.
Old 11-02-2003, 04:20 PM
That Dood's Avatar
also pull the dist car. That has the year of cap production...
toolbox21
01-16-2010 04:59 PM
vla
09-02-2008 10:13 PM
ej8slim
Northern California (Sales)
10-01-2005 04:44 PM
Quick Reply: wut's the different between the engines...
