PS line cut - Q about re-installing PS
Old 03-19-2008, 09:41 AM
dubzz24's Avatar
Default PS line cut - Q about re-installing PS
Ok, so the previous owner of the car took out the power steering pump, and he cut the line that goes from the rack to the pump. It's cut on the rubber section, close to the metal fitting part that actually goes into the pump.
I'm in the process of a b16 SiRII swap and I'd like to reinstall PS, but will I need to get a whole new rack because the hose was cut? Or am I good to just go to a wrecker, cut off the metal fitting, and clamp it to my cut hose? How much pressure is it under?
TIA!
Old 03-19-2008, 09:48 AM
citrus3000psi's Avatar
The rack iteself had threads so you wont need a new rack. I don't remember if the power steering lines that connect to the pump are solid or bolted on. I think they have banjo fittings right? If so just grab a new line.
Old 03-19-2008, 02:12 PM
neo_'s Avatar
Default Re: (citrus3000psi)
NO!
Just order a whole new line. It is screwed in with a NPT fitting into the rack and simply bolted in to the pump.
Old 03-19-2008, 04:04 PM
dubzz24's Avatar
Default Re: (neo_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">It is screwed in with a NPT fitting into the rack</TD></TR></TABLE>
Sweet, just what I wanted to hear. Thanks guys
arziffel
06-08-2012 09:34 AM
Sungsu
08-28-2009 08:38 AM
rmiller
04-04-2008 01:09 PM
Blk00EJ8
07-25-2006 07:36 PM
norice
12-04-2001 09:26 AM
Quick Reply: PS line cut - Q about re-installing PS
