Where can i find the Oem weather-stripping for optional sides and rears???
Been doing some research and cant come up with anything. I dont mind putting them on without but if i can find some i'd put them on. Thanks
Re: Where can i find the Oem weather-stripping for optional sides and rears???
Someone would need to just get 3 packs right? or is there different sizes? I can't remember
Because those pics above are mine. And I installed them. The rears will have some extra, while the sideskirts will almost be right on (you'll end up using the end piece that have the 'teeth').
You will need three.
Did you use the same part number?
got the one for the newest camry rear underspoiler in black. it was 20 for the weather stripping.
If you want Honda weatherstripping go to a Honda dealer and order:
P/N 08F03-SHJ-1100D for black ($19)
P/N 08F03-SHJ-1200D for gray ($19)
It's the replacement weatherstripping for the 08 Civic Sedan optional rear valence and should be long enough to do both rears and sides of the Integra kit. I used Corolla on my ITR kit and when I got my Mugen Si kit I needed to replace the weather stripping so I ordered this and it looks identicle to the real optional rubber.
Here's a pic of it on the Si. It's hard to see on the fiji blue but gives you an idea.
one honda pack will cover the whole kit and a little extra, fwi the honda rubber parts are smaller thinner then the oem acura rubber kit. The toyota looks the same as the kind that comes with the oem kit
good info. one pack of the 07+ camry rear underspoiler will cover all of the oem integra optionals too.
Can this stuff also be used when installing a carbon fiber front lip? My guess is yes, but just thought i'd ask.
ANDREW D
11-24-2004 08:38 PM
