Water Pump
Steve at Heart
Re: Water Pump
Also time plays a factor in belt changes. Even though it is only 67k a water pump, timing belt and tensioner is cheap in the long run.
When was the coolant last changed?
Re: Water Pump
The coolant was last changed about two months ago.
A water pump from Honda in the UK is more like £100. Roughly $170.
#1 Super Guy
Re: Water Pump
OEM Honda water pumps are made by both Yamada (YNA), Aisin & Keihin. You can usually get Aisin pumps in an Aisin without the embossed Honda logo (in an Aisin box) for much cheaper. YNA & Keihin don't sell in an aftermarket box.
All that being said, you could simply inspect your pump and see if it needs replacing. Any excessive coolant stains (more than a drip from the bleed hole), difficulty turning the pulley by hand, noisy when turning, or the bearing feels funny as you turn it....means replace the pump.
Honda/Aisin:
Honda/Yamada (YNA):
Old Honda Keihin:
Honda/Aisin:
Honda/Yamada (YNA):
Old Honda Keihin:
njracer
01-10-2008 05:07 PM
spluvs2install
08-26-2006 07:40 PM
antondaz
09-06-2004 07:22 PM
1998hondaaccord
09-18-2003 05:00 PM
JDM DC2
08-29-2002 11:39 PM
