tranny fluid
1 Post
Re: tranny fluid (princeallure)
check out the FAQ sticky at the top of the board! I think its covered in there .
Edit: I tend to use A&W rootbeer though, make sure to change it frequently .
Honda Manual Tranny fluid is the best.. Cant go wrong with it. Then again, there are other stuff out there so its up to you. Stay stock and nothing goes wrong.
Re: tranny fluid (RealTypeR2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RealTypeR2 »</TD></TR><TR><TD CLASS="quote">Honda Manual Tranny fluid is the best</TD></TR></TABLE>
I dont know about that. It is good, but not the best. IMHO, Pennzoil synchromesh aka GM synchromesh (non friction modified) is better then Honda MTF, especially when your mission is cold.
Re: tranny fluid (Two_K Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Two_K Si »</TD></TR><TR><TD CLASS="quote">I dont know about that. It is good, but not the best. IMHO, Pennzoil synchromesh aka GM synchromesh (non friction modified) is better then Honda MTF, especially when your mission is cold.</TD></TR></TABLE>
Its also alot thinner.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by princeallure »</TD></TR><TR><TD CLASS="quote">What does everyone use for tranny and differential fluid?</TD></TR></TABLE>
Motul Gear300.
What's your use of the car? If its a street car, then Honda MTF. Track car, look elsewhere IMHO.
Motul Gear300.
Re: tranny fluid (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">Its also alot thinner.</TD></TR></TABLE>
Hmm...would you happen to know the vis of the pennzoil synchromesh ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Two_K Si »</TD></TR><TR><TD CLASS="quote">Hmm...would you happen to know the vis of the pennzoil synchromesh ?</TD></TR></TABLE>
OEM Honda
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Titanium -0
Silver - 0
Copper - 0
Lead - 0
Tin - 0
Aluminum - 0
Nickel - 0
Iron - 0
Chromium - 0
Sodium - 0
Boron - 1
Silicon - 0
Water - 0
Soot - 0
Glycol - 0
Moly - 0
Magnesium - 11
Calcium - 2652
Barium - 0
Phosphorous - 1401
Zinc -1564
Visc@100C - 11.26
Tan mg/g - 0.30
Redline MTF and MT-90:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Redline MT-90 5/12/2003
Metal
Iron (Fe) 2
Copper (Cu) 0
Chromium (Cr) 0
Aluminum (Al) 3
Lead (Pb) 3
Tin (Sn) 6
Silicon (Si) 15
Sodium (Na) 18
Potassium (K) 21
Molybdenum (Mo) 1
Phosphorus (P) 2410
Zinc (Zn) 2750
Calcium (Ca) 2840
Magnesium (Mg) 11
Physical
Water (W) N
Fuel (F) /
Antifreeze (A) /
Viscocity At 40 C (V40) 0
Total Acid Number (Tan) 1
Total Base Number (Tbn) 3
Viscosity At 100 C (V100) 14.3
Particle </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Redline MTL 5/12/2003 Analysis by Dyson
Metal
Iron (Fe) 1
Copper (Cu) 0
Chromium (Cr) 0
Aluminum (Al) 3
Lead (Pb) 3
Tin (Sn) 5
Silicon (Si) 25
Sodium (Na) 21
Potassium (K) 11
Molybdenum (Mo) 1
Phosphorus (P) 2520
Zinc (Zn) 2820
Calcium (Ca) 2860
Magnesium (Mg) 11
Physical
Water (W) N
Fuel (F) /
Antifreeze (A) /
Viscocity At 40 C (V40) NR
Total Base Number (Tbn) 4
Viscosity At 100 C (V100) 11.2
Iso Code Rating (Iso) 19/12</TD></TR></TABLE>
Motul Gear 300: (100% Synthetic-Ester based GL-4/GL-5 gear oil. It claims 0% shear loss)
cSt at 40c = 72.6
cSt at 100c= 15.2
Pennzoil Synchromesh (similar to GM Synchromesh)
cSt at 100c = 9.08 (very thin)
OEM Honda
Silver - 0
Copper - 0
Lead - 0
Tin - 0
Aluminum - 0
Nickel - 0
Iron - 0
Chromium - 0
Sodium - 0
Boron - 1
Silicon - 0
Water - 0
Soot - 0
Glycol - 0
Moly - 0
Magnesium - 11
Calcium - 2652
Barium - 0
Phosphorous - 1401
Zinc -1564
Visc@100C - 11.26
Tan mg/g - 0.30
Metal
Iron (Fe) 2
Copper (Cu) 0
Chromium (Cr) 0
Aluminum (Al) 3
Lead (Pb) 3
Tin (Sn) 6
Silicon (Si) 15
Sodium (Na) 18
Potassium (K) 21
Molybdenum (Mo) 1
Phosphorus (P) 2410
Zinc (Zn) 2750
Calcium (Ca) 2840
Magnesium (Mg) 11
Physical
Water (W) N
Fuel (F) /
Antifreeze (A) /
Metal
Iron (Fe) 1
Copper (Cu) 0
Chromium (Cr) 0
Aluminum (Al) 3
Lead (Pb) 3
Tin (Sn) 5
Silicon (Si) 25
Sodium (Na) 21
Potassium (K) 11
Molybdenum (Mo) 1
Phosphorus (P) 2520
Zinc (Zn) 2820
Calcium (Ca) 2860
Magnesium (Mg) 11
Physical
Water (W) N
Fuel (F) /
Antifreeze (A) /
cSt at 40c = 72.6
cSt at 100c= 15.2
