Torque Spec for ITR front caliper bolts
Hi,
Im swapping out the front pads on my accord v6, havnt dished out for the helms yet, so if you can, look up the torque specs for the ITR caliper.
Thanks
Thanks
Re: Torque Spec for ITR front caliper bolts (UCBGSR)
While i don't have the Helms in front of me if memory serves correctly the torque spec on the caliper bolt is 23 fl lbs and the caliper mounting bolt (17mm bolt) is 80 fl lbs. Anyone feel free to correct me if i am slightly off on the 23 flt lbs but the caliper mounting i know is 80
Re: Torque Spec for ITR front caliper bolts (EleanoR)
the 14mm bolt is 36 ft lbs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EleanoR »</TD></TR><TR><TD CLASS="quote">While i don't have the Helms in front of me if memory serves correctly the torque spec on the caliper bolt is 23 fl lbs and the caliper mounting bolt (17mm bolt) is 80 fl lbs. Anyone feel free to correct me if i am slightly off on the 23 flt lbs but the caliper mounting i know is 80</TD></TR></TABLE>
close...the back is 24, but the front is 36.
ray.riddler92
07-27-2011 05:07 PM
onwisconsin81
04-05-2010 01:25 AM
