Tips on removing the climate control? - Honda-Tech
Old 04-23-2004, 03:07 PM   #1
is3oo's Avatar
Default Tips on removing the climate control?
Is there anything I need to know? Do I just pull it out?
is3oo is offline   Reply With Quote
Old 04-23-2004, 03:10 PM   #2
Audi A4's Avatar
Default Re: Tips on removing the climate control? (Type-Rizzle)
there are screws behind the hazard and defront bottons..also theres a cable connected
Audi A4 is offline   Reply With Quote
Old 04-24-2004, 04:37 PM   #3
is3oo's Avatar
Default Re: Tips on removing the climate control? (DRAG lll INTEGRA)
Thanks.
Old 04-24-2004, 04:41 PM   #4
cable is located on the passenger side of the console, behind where the lighter is..
Chris is offline   Reply With Quote
Old 04-24-2004, 09:42 PM   #5
is3oo's Avatar
Default Re: Tips on removing the climate control? (Chris)
Quote:
That shouldn't be a problem since I'm missing the whole ashtray and lighter console.
Old 05-03-2004, 11:24 PM   #6
is3oo's Avatar
I get what you guys were saying now. How do you disconnect that cable which controls the temperature?
Old 05-04-2004, 12:24 AM   #7
ilovemyhonda's Avatar
If you look under your dash on the passenger side you will see a cable connected to a metal post. Just pull the cable off the post and you should be fine.
Here are some pictures from team-integra.net
ilovemyhonda is offline   Reply With Quote
Old 05-04-2004, 01:20 AM   #8
Dc2 Powered's Avatar
why do you want to remove it? going add boost controler or a gauge or controler of some type?
Dc2 Powered is offline   Reply With Quote
Old 05-04-2004, 02:44 PM   #9
is3oo's Avatar
Default Re: Tips on removing the climate control? (ilovemyhonda)
Thanks for the pic. It was very helpful. Now do I pull the whole climate control out with the cable attached to it?
Old 05-04-2004, 07:21 PM   #10
sykotic's Avatar
yes, the cable is attached to the cold/hot dial, its a real bitch to get the 3 pieces of that climate control apart to take the cable off of the climate control unit, just pull the cable out with it, take note of how the cable is routed through the center console for when you reinstall it, otherwise you may not be able to reach full hot or cold.
sykotic is offline   Reply With Quote
I have a stalker acmoc General Discussion and Debate 35 01-16-2017 04:12 PM
My ear hurts hondur General Discussion and Debate 3 05-05-2016 04:50 AM
Engine for sale? I Am White Acura RSX DC5 & Honda Civic EP3 6 04-26-2007 06:54 AM
i am new to this crxsteve Honda CRX / EF Civic (1988 - 1991) 3 07-18-2006 11:25 PM
how do I post a picture?? 02spoon For Sale 2 11-03-2005 06:42 PM
Tags
climate, control, integra, is300, remving, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
