Timing setting with milled head
Old 04-01-2004, 08:51 AM
iperez's Avatar
Default Timing setting with milled head
How much should I retard my ignition timing now that I am installing a .020 milled head ?? BTW, the chambers were re-shaped to gs-r style so compression will be increased further than the milling. Thanks !!
Old 04-01-2004, 01:31 PM
Racebrewer's Avatar
Default Re: Timing setting with milled head (iperez)
Best ignition timing would depend upon a number of factors including the gasoline available to avoid detonation.
The other problem is that your cam timing has changed now being retarded 1.5-2.0 degrees shoving the power band up a bit. You might want to consider adjustable cam gears along the way to compensate, especially if you change cams.
John
Old 04-01-2004, 06:30 PM
Finland's Avatar
Default Re: Timing setting with milled head (Racebrewer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racebrewer &raquo;</TD></TR><TR><TD CLASS="quote">Best ignition timing would depend upon a number of factors including the gasoline available to avoid detonation.
John</TD></TR></TABLE>
werd...definitely get some adjustable cam gears..
Old 04-02-2004, 05:25 AM
iperez's Avatar
Done !! I have JUN3s and cam gears .. along with a bunch of other things
Old 04-02-2004, 11:57 AM
Racebrewer's Avatar
Default Re: (iperez)
You're beyond 'recommendations' and into the land of intense tuning.
You need to get the best cam timing, fuel settings, and ignition timing. Perhaps I should have said 'tuning' rather than 'timing'.
Probably the best bet is a stand-alone system where you can control the ignition timing as well as the fuel.
John
DcWest
09-27-2005 12:49 PM
scUba-stEve
13
05-15-2005 08:47 PM
fastcrxsi90
06-20-2003 09:05 PM
redcxhatch
11-16-2002 08:04 AM
Quick Reply: Timing setting with milled head
