Tightening Alternator belt
Whats the easiest way to tighten this belt. Mine has come loose and is sqealing like a little girl. How do i get enough force to get this tight?
Re: Tightening Alternator belt (98TypeR)
loosen the upper nut and lower pivot nut. The lower one can be accessed easily from the wheelwell. There is an area where you can use a prybar to preload the alternator belt. It is on the top and you can see a thick flange on the alternator and an accomodating flange on the engine. I am not sure what the defection is but 3/8"-1/2" at the midpoint of the longest part of the belt is a good rule of thumb. Otherwise, check out your HELM. Then tighten the top nut and then the bottom one.
519[H]Si
05-25-2004 09:25 PM
2001, acura, alternator, aternator, belt, cost, honda, integra, ps, tighten, tightening, tighting, totightening
