Test pipe diameter ? JDM header 2.5" and 2.25" b-pipe
Old 10-28-2002, 07:08 AM
pinota's Avatar
Default Test pipe diameter ? JDM header 2.5" and 2.25" b-pipe
Hello,
I need to replace my cat converter cause itīs ruined.
I have a DC JDM header 2.5" colector and a 2.25" b-pipe.
What diameter should i use to do a test pipe, 2.5" or 2.25" ?
Wich pipe diameter will give me more hp, what benefits and disadvantages of pipe diameter.
Thanks in advance.
Pinota
Old 10-28-2002, 07:14 AM
sackdz's Avatar
Default Re: Test pipe diameter ? JDM header 2.5" and 2.25" b-pipe (pinota)
Hello,
Thanks in advance.
Pinota
Wow, you're still using a 2.25" exhaust? Get rid of that thing, it's only holding you back.
[e]
DC JDM 4-1 /custom twinloop exaust 60mm/Supersprint B-pipe 60mm
Is that the bpipe you're talking about?
Does the flange measure @ 2.25"? The exhuast is 60mm = 2.36"
[ee]Use a 2.5" testpipe.
[Modified by sackdz, 11:21 AM 10/28/2002]
Old 10-28-2002, 10:44 AM
pinota's Avatar
Default Re: Test pipe diameter ? JDM header 2.5" and 2.25" b-pipe (sackdz)
Yes, the b-pipe and the exaust pipe diameter is 60.5mm, the b-pipe flange is 57mm internal. I have in the cat converter a custom flange of 60mm internal.
Old 10-28-2002, 11:00 AM
sackdz's Avatar
Get a 2.5" testpipe and remove the bottleneck(s) from your bpipe.
[Modified by sackdz, 3:01 PM 10/28/2002]
frstwhtgsr2000
12-13-2006 09:48 AM
leboeuf45
08-04-2004 02:11 PM
Heisdan
04-13-2004 08:28 PM
ophdehEEzY
03-04-2003 01:44 PM
Quick Reply: Test pipe diameter ? JDM header 2.5" and 2.25" b-pipe
