single vs. dual... head gasket layers
Old 01-16-2007, 02:06 PM
CXtypeR's Avatar
Default single vs. dual... head gasket layers
using a oem HG
which would be better to use?
pros and cons for each? interested in a power vs. reliability
stock jdm itr head and block
Old 01-16-2007, 02:28 PM
B_CRUZ!'s Avatar
Default Re: single vs. dual... head gasket layers (CXtypeR)
single layer OEM head gaskets have leaked from my experience.
Old 01-16-2007, 02:35 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CXtypeR &raquo;</TD></TR><TR><TD CLASS="quote">using a oem HG
stock jdm itr head and block</TD></TR></TABLE>
power from headgasket?? gasket is for sealing in my book. use the thickest availbalbe as in oem 3 layer and reliability will come along.
Old 01-16-2007, 02:36 PM
RTW DC2R's Avatar
Ive been using dual layer (remove the middle layer) stock gaskets for a long time and never had a problem. I always used a bit of copper sealant as well just in case. Currently Im on a stock 3 layer bored 84.5mm gasket.
Id like to add unless you are looking to squeeze out every last bit of compression on a fully built high compression motor, you arent going to notice a difference.
VPR
09-09-2009 11:37 PM
Speed Infliction
05-02-2006 12:35 PM
94integragsr
02-12-2006 02:24 PM
mrx
10-02-2004 09:08 PM
pinota
05-28-2002 09:30 PM
Quick Reply: single vs. dual... head gasket layers
