Screeching sound when starting car
I get this weird screeching sound when I start the car when its warm. Screeching sound is similar to when you over turn the key when car is on. My friend told me the problem might be around the clutch. I hate EXEDY!
Re: Screeching sound when starting car (IBriaIN)
not sure, but Exedy/Daiken makes the OEM Honda clutches. I have 2, each with nearly 200K miles on it, including track time, without issues.
Re: Screeching sound when starting car (slofu)
some history might help. is this a fresh build, or a fresh clutch/trans/etc.? maybe bad throwout bearing, or one of the springs came loose on it?
just a fresh clutch and a flywheel. Both exedy. When it was installed it made this loud chatter sound when the clutch was depressed and I found out later that this was a common problem with Exedy clutches. So to fix it I had to readjust the clutch so when depressed metal on metal won't rub. Now when I turn on my car it makes this loud screech sound under the hood. Like I said it sounds like the screech when you over turn your key when the car is on. Possibility is the clutch?
Re: Screeching sound when starting car (MiraiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ »</TD></TR><TR><TD CLASS="quote">sounds more like a loose belt to me</TD></TR></TABLE>
My first thought when I read the title.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B »</TD></TR><TR><TD CLASS="quote">
My first thought when I read the title.</TD></TR></TABLE>
x3
x3
Zeino
03-30-2011 01:36 PM
colesd16
06-28-2004 08:22 PM
