IS IT SAFE TO NITROUS ON A B18C5
Old 11-08-2006, 10:24 AM
B-motor's Avatar
Default IS IT SAFE TO NITROUS ON A B18C5
im going a 80 shot direct port on my stock block(b18c5)
will it be safe...... or
what will i need to be safe........HELP
Old 11-08-2006, 10:28 AM
walker111's Avatar
Default Re: IS IT SAFE TO NITROUS ON A B18C5 (B-motor)
NO
Old 11-08-2006, 10:30 AM
BoBo Racing's Avatar
ive never messed around with it but i hear a 50 shot is safe all day i dont know if its true though
Old 11-08-2006, 10:59 AM
Doespike's Avatar
Default Re: IS IT SAFE TO NITROUS ON A B18C5 (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">NO</TD></TR></TABLE>
Old 11-08-2006, 11:02 AM
RTW DC2R's Avatar
Ive done it, it worked great when done right and conservative. Then I got greedy with a 125shot, too much timing and burned up some valves. Make sure its a wet setup, turn the timing back, and run colder plugs.
Old 11-08-2006, 11:04 AM
s2kdre's Avatar
i had a 75shot on my jdm r for a long time, its safe as long as u got good timing and plugs and a fuel pump, ur motor is only 10.6:1 compression thats good, so an 80 shot is gonna be safe, i was running 12degrees of timing and 45psi of fuel at idle. nitrous is safe if its used right.
Old 11-08-2006, 01:15 PM
Doostur's Avatar
Dosn't matter how well built a motor is... when you juice something can always go wrong.
Old 11-08-2006, 01:23 PM
Opie's Avatar
Stop YELLING!
Old 11-08-2006, 09:07 PM
Desired_Speeds's Avatar
please dont
Old 11-08-2006, 09:09 PM
vivid 02's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B-motor &raquo;</TD></TR><TR><TD CLASS="quote">im going a 80 shot direct port on my stock block(b18c5)
what will i need to be safe........HELP</TD></TR></TABLE>
Works Great. Don't need anything
Old 11-08-2006, 09:18 PM
H-PIMP's Avatar
Default Re: IS IT SAFE TO NITROUS ON A B18C5 (vivid 02)
It can be done, especially a light hit in a car with strict maintenance and proper tuning.
There's always the possibility of going kaboom, but I've also seen 80K mile C5's with over 100 bottles and 200+ drag passes on them, that ran as if they were never sprayed in their life.
Bottom line is, that even if you address all the preventative issues with a nitrous set up, a little bit of luck never hurts.
soriano4521
08-30-2005 12:27 PM
dpw41285
02-18-2005 07:56 PM
HotImportNightHonda
09-23-2004 09:43 AM
Greenery18
07-27-2004 09:33 PM
ninja8oi
11-21-2003 12:53 AM
Quick Reply: IS IT SAFE TO NITROUS ON A B18C5
