Rear camber problems
i'm lowered about 2 inches on B+G full coilovers. i've gotten an alignment for my poor negative camber, but the top of the wheel still remains tilted in.
the treadwear is fairly bad, and i get a lot of road noise. i tried the "washer trick" and even put in 5 washers between the rear upper control arm bolt and the well wall.
it really did nothing. so i'm wondering about whether or not i should just go buy a rear camber kit, because i cant afford to have sets of tires wear unevenly like this.
i was hoping the washer trick would work, but it didn't and i need some tips on what to do. thanks.
Re: Rear camber problems (tekkynikality)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekkynikality »</TD></TR><TR><TD CLASS="quote">i'm lowered about 2 inches on B+G full coilovers. i've gotten an alignment for my poor negative camber, but the top of the wheel still remains tilted in.
i was hoping the washer trick would work, but it didn't and i need some tips on what to do. thanks.</TD></TR></TABLE>
You do know the alignment shop cannot adjust camber without you having a kit, right? I have never seen the washer trick not work for anyone. Have you checked for bent suspension pieces?
FalkenSiR
Suspension & Brakes
06-06-2006 11:06 AM
9civic8
Suspension & Brakes
13
08-29-2005 05:01 PM
