Question on using torque wrench
When using a torque wrench, are you supposed to set it back to 0 before setting it to the next number?
The techs at my friend's work (Chevy dealer) said that they alwasy do this..and if you dont then the wrench is not accurate.
I sure hope this isnt true, cause if it is..my whole engnine is torqued wrong!
Re: Question on using torque wrench (HX_Guy)
I use a Craftsman Digitork wrench, and it only goes from 25 to 80. They tell you not to turn the dial higher or lower than these numbers
Re: Question on using torque wrench (Floyd)
That is a good point, the wrench I use is a Craftsman as well and it doesnt go lower then 20..so there is no way to 0 it out. Hmm
stick with the simple ones, if you've got spare cash, go snap on.
D
Hey HX,
I wouldn't worry about it. Your engine bolts are torqued just fine. You don't have to go back to zero before re-adjusting the setting. Especially if you are moving up in the readings like when torquing a head.
In between using the wrench,it probably is a good idea to set it to zero or at least a fairly low setting before putting it away.
BTW, what does the sign in your avatar say?
John
John
D Tranny Guru
I got a 30 year old craftsman torque wrench. Has been set on 85 for 4 years now. I took it to Snap-On truck to be tested. Mine was the most accurate of the ones tested at 30,60, and 90 settings. 3 brand new Snap-On's weren't even close!
THANKS DAD (r.i.p.) for the tools and tips.
oh my!!...hmmm what about a B-20 ITR?....
-I mean yeah what steve said, when not in use, put it back to the lowest setting, and get it calibrated
Re: Question on using torque wrench (NAB20C5)
Nice, do you know that girl HX guy, or do you just get random girls to strip for you? i have a craftsmen torque wrench and i never set it back to 0, don't worry about it. Do you still have the directions? I am sure it would say to set it back to 0 in the directions somewhere.
Re: Question on using torque wrench (the real steve c)
BAHAHAHAHA...that is too funny
Oh that **** ... check out what she sent me a while back...
Junkyard2000
01-15-2006 10:00 PM
92hatchattack
07-19-2004 08:53 PM
