Question Regarding Water Pump Replacement
Plan to do this at some point and have a question regarding something that is mentioned in the Acura Service Manual 1996 Integra.
Do I need to remove the cam pulley's and rear timing cover to change the water pump on a JDM B18C!?
Thanks,
Tom
Thanks,
Tom
Re: Question Regarding Water Pump Replacement
If you are talking about the upper and lower plastic covers on the timing belt side then yes you do need to remove both. Might as well change the timing belt and tensioner since you are there anyway.
NFrank89
10-19-2010 06:59 AM
lv6l
10
10-13-2005 07:27 AM
