Question about ITR Gearbox...
Old 07-20-2004, 08:48 PM
REDTOPAlchemy's Avatar
Default Question about ITR Gearbox...
I have been noticing for a while now that when I am driving my R and I try to downshift into first (at 2-3 miles an hour....an absolute crawl...usually when I go over speedbumps or dips) it won't go without a fuss...sometimes a little slapping sound but not like a grind. I kinda have to force it in which I'm very reluctant to do. Is this the way the ITR manual transmission is built, or has something gone south in my gearbox?
Old 07-20-2004, 08:51 PM
uNF$@#!'s Avatar
Default Re: Question about ITR Gearbox... (PYXITR)
1st gear is not syncronized, so you either rev match, or deal with the issue
Old 07-20-2004, 09:16 PM
Default Re: Question about ITR Gearbox... (Captain Commando)
Thanks for the info. I see...so my other question for you would be:
Is it damaging the gearbox when you don't rev match and try to shift into first at a slow speed? If it is...in what way is it damaging the manual trans.?
Old 07-21-2004, 03:18 AM
.RJ
.RJ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Captain Commando &raquo;</TD></TR><TR><TD CLASS="quote"> 1st gear is not syncronized</TD></TR></TABLE>
You sure on that?
Old 07-21-2004, 05:21 AM
rainman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Captain Commando &raquo;</TD></TR><TR><TD CLASS="quote"> 1st gear is not syncronized, so you either rev match, or deal with the issue </TD></TR></TABLE>
If that was the case, how do you explain shifting into 1st at a dead stop without grinding? A non synchro box will always make a ton of noise when doing this. I'm really curious about this.
Old 07-21-2004, 08:34 AM
Seedc2's Avatar
Default Re: Question about ITR Gearbox... (rainman)
i thought reverse didnt have synchros?
Old 07-21-2004, 08:35 AM
PM-Performance's Avatar
every manual car i have ever driven has been like that.
Old 07-21-2004, 10:09 AM
01-1293's Avatar
Default Re: Question about ITR Gearbox... (itr206)
100% normal.......sometimes a quick clutch down into 2nd gear and then 1st gear will do the trick...helps line the teeth up
btw 1st gear does have a syncro
don't force it in...if it's not going into gear there is a reason
Old 07-21-2004, 10:19 AM
Default Re: Question about ITR Gearbox... (01-1293)
So what possible damage results from forcing it into gear...with the clutch all the way...just gears not meshed?
Old 07-21-2004, 11:30 AM
Anybody?
Old 07-21-2004, 01:29 PM
01-1293's Avatar
thats the syncro grinding......if you really ream on it eventually you will have to replace the syncro
Old 07-21-2004, 01:40 PM
BERT-O's Avatar
1st gear does have synchros, its 1-2 set, then you have 3-4 set and last 5-R sets.
As far as your questions goes, change your fluid if you havn't had so. Also check the fluids on the slave cylinder, those tend to go bad, no matter what mileage of the car have!
Old 07-21-2004, 01:41 PM
I see. Can you define "really reaming on it."
screaminj
Honda Fit
10-29-2007 05:57 PM
MOVE OVER
03-12-2005 02:12 PM
b20vtecEK
03-01-2004 12:40 PM
Loveless
06-23-2003 09:40 PM
comptechgsr
05-09-2003 03:19 PM
Quick Reply: Question about ITR Gearbox...
