Proper OEM lug nut torque specs ? - Honda-Tech
Old 10-14-2003, 08:38 PM   #1
TypeRuz's Avatar
Default Proper OEM lug nut torque specs ?
Also, it as always important to use a torque wrench for putting wheels on car?
or can i just "feel" for the proper torque?
i've heard it's bad to torque way above specs....may warp rotors. of course, below specs can be bad for obvious reasons.
TypeRuz is offline   Reply With Quote
Old 10-14-2003, 08:40 PM   #2
BlueR's Avatar
Default Re: Proper OEM lug nut torque specs ? (typeruz)
80 lbs and buy a torque wrench it has other uses too
BlueR is offline   Reply With Quote
Old 10-14-2003, 08:45 PM   #3
D
about 'yay' much.
D is offline   Reply With Quote
Old 10-15-2003, 05:06 PM   #4
People_Mover's Avatar
Location: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Proper OEM lug nut torque specs ? (D)
Quote:
Originally Posted by D
about 'yay' much.
yeah, D always uses his vocal chords as a torque wrench. click clock. lol
People_Mover is offline   Reply With Quote
Old 10-16-2003, 07:41 AM   #5
sil
sil's Avatar
Quote:
i've always wondered about this, but I would've thought that the warping of rotors comes from using different torque amount on all 4/5 lugs as opposed to using a number different 80ftlb.. in other words if you consistently use X ftlb on all lugs you'll be OK.. if that's the case, are torque specs given to save your threads?
sil is offline   Reply With Quote
Old 10-16-2003, 09:07 AM   #6
H-T Order of Merit
Default Re: Proper OEM lug nut torque specs ? (sil)
You should always use a torque wrench.
Here is a nice one for only thirty bucks. It's money well spent.
nsxtasy is offline   Reply With Quote
Old 10-16-2003, 09:12 AM   #7
i like to use a torque wrench.. but when one is not around, just make sure they're on there pretty snug.. and of course in a star pattern.
jonas is offline   Reply With Quote
Old 10-16-2003, 09:37 AM   #8
D
Default Re: Proper OEM lug nut torque specs ? (nsxtasy)
Quote:
you sir, are a retard. many things need an appropriate bolt stretch that should be measured... ie, rod caps, main caps, tranny components... others can be rednecke'd with no issues.
D
Old 10-16-2003, 09:52 AM   #9
Johnny Tran's Avatar
D,
whats the battle torque spec for my license plate screws?
Johnny Tran is offline   Reply With Quote
Old 10-16-2003, 10:11 AM   #10
AssPenny's Avatar
Default Re: Proper OEM lug nut torque specs ? (Johnny Tran)
Same as the oil drain plug
AssPenny is offline   Reply With Quote
Old 10-16-2003, 10:19 AM   #11
Default Re: Proper OEM lug nut torque specs ? (AssPenny)
Quote:
cool...so ill just put it on like the plug, with my air gun.
thanks craig
Old 10-16-2003, 10:20 AM   #12
H-T Order of Merit
You, sir, are very quick to throw nasty insults around without any provocation. Perhaps you are having a bad day. (Cubs fan, perhaps?)
You also ignore the fact that the question was asked about lug nuts and it would be reasonable for anyone to assume that my response should be taken within this context. However, since you are clearly more interested in attacks than in having a reasonable discussion, I will rephrase my response:
You should always use a torque wrench when tightening wheel lug nuts.
Old 10-16-2003, 11:53 AM   #13
Alexander's Avatar
I agree.
Alexander is offline   Reply With Quote
Old 10-16-2003, 02:13 PM   #14
Jason's Avatar
...and license plate bolts
Jason is offline   Reply With Quote
Old 10-16-2003, 02:26 PM   #15
Darth ModerVader
Padawan's Avatar
Default Re: Proper OEM lug nut torque specs ? (Jason)
Quote:
But then sometimes they don't end up with the screw-heads vertically aligned.
Padawan is offline   Reply With Quote
Old 08-21-2009, 05:04 PM   #16
R_ACE1's Avatar
Quote:
I agree.
I second that notion.
R_ACE1 is offline   Reply With Quote
Old 08-21-2009, 06:13 PM   #17
Use the torque wrench, and avoid "breaking off" a bolt/stud. Replacing a broken bolt isn't as easy to replace on Acuras, as they are to replace on Fords, Dodges, and GM cars.
safedriver is offline   Reply With Quote
Old 08-21-2009, 11:37 PM   #18
srt4mike's Avatar
Of course you can just guess, but it is definitely a best practice to use a torque wrench whenever possible. Guessing works fine and dandy until you mess something up.
srt4mike is offline   Reply With Quote
Old 08-24-2013, 10:43 PM   #19
If you over torque the lugs you can damage the threads and risk the lugs falling off or having to cut a stud because you can't get the lug off. that is why you should use a torque wrench to tighten lugs but as long as you don't go he-man strength and just get them tight with a 4way or however you personally do it you should be good
HMBunch is offline   Reply With Quote
Old 08-25-2013, 02:41 PM   #20
mafia's Avatar
You should look at the date, this thread is from 2003.
mafia is offline   Reply With Quote
torque specs Civic483973 Honda Civic / Del Sol (1992 - 2000) 1 06-21-2010 12:33 PM
b18c5 top end/head torque specs!? 01_ITR Acura Integra Type-R 4 09-05-2008 09:31 AM
spoiler torque specs? dc0166 Acura Integra Type-R 5 10-23-2004 12:28 AM
Header torque specs . . . WangChung Honda Civic / Del Sol (1992 - 2000) 8 03-29-2003 04:13 PM
Torque Spec on Lug Nuts for Rims???? jdm jedi Honda Civic / Del Sol (1992 - 2000) 8 03-19-2002 10:24 AM
Tags
acura, crx, honda, integra, lug, nut, nutts, rsx, spec, specs, tl, torc, torque, type, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
