problem with taking key out
Old 10-22-2002, 05:33 PM
HybridGSR1's Avatar
Default problem with taking key out
the weirdest thing happened today... as i parked my car in my driveway... the key apparently got stuck.. like it would not come out at all.. it stays at the 1st click..i can still start the engine and drive it around but the key just seem like its stuck when i try to take it out.. what could be wrong?? u guys know anyway to take out the key?
Old 10-22-2002, 05:40 PM
jetydosa's Avatar
Default Re: problem with taking key out (HybridGSR1)
You probably just locked the steering wheel by accident. Can you turn the wheel at all? If not, then turn the steering wheel kinda hard (you will have to use a little force) to one direction while pushing in/turning the key.
Old 10-22-2002, 05:41 PM
HybridGSR1's Avatar
Default Re: problem with taking key out (Jetydosa)
nah the steering wheel isnt locked...
the car still has the key in it sitting in the garage as we speak.. help!!!!!!
[Modified by HybridGSR1, 2:42 AM 10/23/2002]
Old 10-22-2002, 06:10 PM
NunRacer's Avatar
My girlfriends Civic did the same thing a few times. Apparently it's sort of a defect from factory. We took the Civic to Honda they replaced something under warranty and has never happened again.
Old 10-22-2002, 07:01 PM
baonest1's Avatar
Default Re: problem with taking key out (NunRacer)
i was in my boss' carrera 4s and well the wheel was locked, but that was the last thing on my mind. so i was like, umm what the hell i thought i messed his car up cuz i was screwing with the key and alarm. so he comes and unlockes the wheel and i go for a drive..
Old 10-22-2002, 07:36 PM
Leo
Leo's Avatar
Something must be wrong with one of the tumblers.
Old 10-22-2002, 07:53 PM
IGGY's Avatar
Default Re: problem with taking key out (ITR 01-0166)
turn the wheel from side to side while you turn and pull the key and/or wiggle the key a little to see of slips out.
Old 10-23-2002, 12:37 AM
kkim's Avatar
try lubricating the lock mechanism with a light lube. just spray it in where the key goes into the ignition. sometimes dirt/whatever gets into the tumblers and freezes them.
Old 10-23-2002, 06:13 AM
Bbasso's Avatar
Ya have to put in park to release the key-
Old 10-23-2002, 01:30 PM
HybridGSR1's Avatar
Default Re: problem with taking key out (Bbasso)
its actually an automatic honda passport.. for you guys's info... the key still wont come out.. its been 2 days already .. shieT!
Old 10-23-2002, 01:35 PM
slowassR's Avatar
sometimes you got to turn the wheel abit.
Old 10-27-2002, 05:23 PM
EG6owner-T's Avatar
Default Re: problem with taking key out (slowassR)
ok this happens on my bro auto civic when he just installed a shift ****. take out the negative cable on your battery then you should be able to take it out for now. if that was it then fix your auto shifter.
if that dont work then readjust your ****. hehe
if it stills dont work then you're screwed, nah i just dont know. thats my $0.02
Old 10-27-2002, 05:25 PM
EpDarks's Avatar
Default Re: problem with taking key out (EG6owner)
One time my friend actaully BENT his key inside his ignition. It was stuck in there for a long time.
Sounds stupid but check it out.
Old 10-28-2002, 04:15 AM
EG6owner-T's Avatar
let me know if you tried it.
Old 10-28-2002, 10:01 AM
HybridGSR1's Avatar
i tried everything it just wont work
Old 10-28-2002, 10:28 AM
EG6owner-T's Avatar
damn that sucks hard. take it to the dealer and tell them honda sucks haha
Old 10-28-2002, 10:45 AM
AssPenny's Avatar
My x's CRV would do that every once in a while. We figured out that if you put the car in drive, and roll foward a bit, then step on the brake, put it in park, and take the key out, while your foot is still on the brake. Never did figure out what the problem was, it was went away after a little while.
Old 10-28-2002, 11:38 AM
Tommy_Gunns's Avatar
Tow it to honda and get that biatch fixed.
Old 10-28-2002, 03:15 PM
baonest1's Avatar
Default Re: problem with taking key out (Tommy_Gunns)
if you have time, take off your ignition. and fiddle with it. or you can just drive it to honda (if it drives) .
peace
see vick
12
03-05-2021 05:49 AM
kreeves
06-24-2008 06:06 PM
FaK iTz JaSoN
Honda Civic (2001 - 2005)
14
10-10-2007 08:40 AM
JamiAaryn
01-05-2007 05:00 PM
XplodeTeg
10-26-2004 03:52 PM
Quick Reply: problem with taking key out
