Possible reasons for steering wheel vibration? - Honda-Tech
Old 07-02-2002, 06:00 AM   #1
Nuts's Avatar
Default Possible reasons for steering wheel vibration?
I've noticed the steering wheel vibrates when the car reach to 120km/h (75mph) and the vibration stops when it reach around 140km/h (87.5mph). What could be the possible reason?
I've been told that it might be my tires are off balance. I will bring the car in the shop soon but just want to know what to expect.
btw, my stock tires has 25K km (15K miles) , been on the track 2 times and the left side of each tires are bladed (pretty much) since there are lots of right hand turns on the track that I ran on.
TIA,
CS
Nuts is offline   Reply With Quote
Old 07-02-2002, 06:21 AM   #2
JPP
Default Re: Possible reasons for steering wheel vibration? (CS)
Highest probabilty is an unbalance wheel. Either the tire as uneven wear or you lost a balancing weight.
JPP is offline   Reply With Quote
Old 07-02-2002, 07:08 AM   #3
TypeR 599's Avatar
Default Re: Possible reasons for steering wheel vibration? (JPP)
i think he lost a weight
TypeR 599 is offline   Reply With Quote
Old 07-02-2002, 07:16 AM   #4
Nuts's Avatar
Default Re: Possible reasons for steering wheel vibration? (TypeR 599)
you mean I lost one of those metal piece on the wheel?
time to do re-balancing I guess.
btw, why would it only vibrates at 120km/h but not at a higher speed?
thanks,
CS
[Modified by CS, 3:20 PM 7/2/2002]
Old 07-02-2002, 07:36 AM   #5
Cosworth's Avatar
your alingment could be off, if you hit something on the road recently.
Cosworth is offline   Reply With Quote
Old 07-02-2002, 07:40 AM   #6
Wiseguy's Avatar
Default Re: Possible reasons for steering wheel vibration? (Cosworth)
you need "wheel alingment " on your car
Wiseguy is offline   Reply With Quote
Old 07-02-2002, 07:47 AM   #7
VTHokie's Avatar
Default Re: Possible reasons for steering wheel vibration? (Wiseguy)
Could be a broken radial belt, that is what honda found on my new potenza's I guess that teaches me for having walmart mount my tires
walmart = tire mounting
walmart = fried chicken
Eric
VTHokie is offline   Reply With Quote
Old 07-02-2002, 10:22 AM   #8
Incognito's Avatar
Default Re: Possible reasons for steering wheel vibration? (VTHokie)
try to put your rear wheels on the front, fronts in the rear, and see if the car still vibrates. If it does, then it's your wheels (balancing, tires, or wheels). If not, then it's somehting in your suspension.
Incognito is offline   Reply With Quote
Old 07-02-2002, 10:29 AM   #9
Big Phat R's Avatar
Default Re: Possible reasons for steering wheel vibration? (Incognito)
exactly - but it sound like a front wheel is out of balance or you bent the rim
Big Phat R is offline   Reply With Quote
Old 07-02-2002, 06:33 PM   #10
TypeR 599's Avatar
thanks,
CS
okay...i know for sure the wheel is out of balance because it only vibrates at a certain speed. This is because the frequency of vibration the road and tires are exactly the same only at 120km/h. i bet at any other speed, from teh outside, you can see your tire wobble but you wont be feeling it because the frequencies are not matched.
btw, if you are socal, i can balance it for you free
yeh, you probably did lose one or it moved out of it's original position some how..
[Modified by TypeR 599, 6:35 PM 7/2/2002]
Old 07-02-2002, 06:50 PM   #11
New User
JDM nerbie's Avatar
it could be you have dirt or somthing stuck on the inside of the wheel throwing your wheel(s) off balance
just and idea
or what everyone else said
JDM nerbie is offline   Reply With Quote
Old 07-02-2002, 09:24 PM   #12
Incognito's Avatar
Default Re: Possible reasons for steering wheel vibration? (nerbieR)
if you have those sticky weights, you probably lost 1 or 2. They just fly off over time. look for like some sponge/glue **** on the inside of your rim, if U run sticky weights. That could be a sign of a sticky weight that have flown off.
Help with exhaust Andy Garcia Honda Civic (2006 - 2015) 0 07-07-2016 02:14 PM
2012 Accord Vibration at High Speed JCO737 Honda Accord & Crosstour (2003 - Current) 3 04-11-2016 07:01 AM
Steering Wheel Shakes, plus Intermitten Body Vibration gaplarge Suspension & Brakes 1 11-09-2010 02:42 AM
Stering wheel shakes, plus acceleration vibration and car shakes at higher speeds gaplarge Suspension & Brakes 1 11-08-2010 09:40 PM
JDM cluster...R baonest Acura Integra Type-R 15 07-13-2002 06:26 AM
Tags
120, 140kmh, 2001, 95, acura, bmw, evo, hondatech, integra, km, steering, tl, vibration, vibrations, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
