how to get 12's all motor?
Re: how to get 12's all motor? (braweebsta)
Ehhh... Sell the ITR and buy something that does the quarter mile in 12 s. Problem solved....
New User
Re: how to get 12's all motor? (Pinhead)
well then I decide to go this route
definitely 12's but not on street tires...that's basically impossible
sell your R buy my R problem solved
you will never touch it without slicks. ask incognito though, he hit like 12.96, basic boltons, cams , tuned, milled head, slicks and susp work . . . . . he got quite a bit wrapped up in that car. . . its very impressive.
also sgt is ther too , but i think he;s stroked too. . . . basically like they said, bend over and get your credit cards ready.
A better clutch would help also... I`ve noticed the stock clutch slips a little bit when shifting at high runs
Re: how to get 12's all motor? (sgT)
Doesn't take too too much to run 12's.
Cheapest way all motor is probably by cams, cam gears, valvetrain, head mill, clutch, slicks, header, intake, weight reduction. Don't need headwork, bottom end work or tranny modifications to crack 12's.
Good luck
Good luck
Re: how to get 12's all motor? (Incognito)
Good luck
Good luck
Good luck
Good luck
Are you saying that with my setup, I might be able to hit 12's with slicks? Or do I need the ditch the GSR tranny for something with shorter gearing like the JDM ITR 4.785 FD
