parking brake adjustment? - Honda-Tech
Old 03-25-2012, 04:08 PM   #1
Default parking brake adjustment?
So I just finally completed my first brake job on my R. I've never done such a big job before. I changed out rotors and pads. Now using brembo blanks and hawk hps pads. Was alot of work to do, but luckily I had the service manual and some good tools to make the job smoother then it would have been w/o my trusty cordless 18v impact wrench. Im investing in an impact driver for next time around.
But a big issue came up just a few minutes ago, my car was parked in my driveway with a fairly good incline and my friend just leaned against the bumper and the car started to roll slowly down the driveway!!!!!! When these hawk pads are cold, they dont stop as well as cold OEM pads. The handbrake was pulled to about the usual 6 or so clicks, never had this issue before I did the brake job.
Is it common to re-adjust the hand brake after putting new pads/rotors in? If not, I think I need to recheck my work! lol!
Thanks for any info!
TypeRod is offline   Reply With Quote
Old 03-25-2012, 04:20 PM   #2
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
Default Re: parking brake adjustment?
The handbrake is kinda loose sometimes after pads and rotors because you have to twist the mechanism all the way back to put in the new brakes. I would rip the e brake up and down a few times to see if it gets better. If not, the adjuster for the E brake is a 12mm nut that you access by removing the arm rest/console. It's a nut that pulls the cables tighter. It'll be obvious when u remove the arm rest.
B serious is offline   Reply With Quote
Old 03-25-2012, 04:25 PM   #3
Quote:
Thanks for the info B! I just found the procedure in my service manual, and it has all the pretty little pictures that I love so much! hehe!
Thanks again!
Old 03-25-2012, 04:32 PM   #4
Hybrid96EK's Avatar
Adjust so it holds the car still in 7-10 clicks
Hybrid96EK is offline   Reply With Quote
Old 03-25-2012, 04:47 PM   #5
Quote:
Will do! Thank Hybrid!
Hawk PC Brake Pads: I Think I HATE Them... DarryCar Suspension & Brakes 33 03-10-2016 08:08 AM
Issue With Brake Rotors Warping 92ehatch Honda Civic / Del Sol (1992 - 2000) 17 12-17-2009 02:31 PM
brakes, need help. Babakarab Acura Integra 6 05-12-2007 11:12 AM
Problem with the brakes, need second opinions Drag'nGT Honda Prelude 2 02-21-2006 11:41 AM
Got my rear brakes done, work great as a parking brake but not e-brake TiggsCRX Honda CRX / EF Civic (1988 - 1991) 5 05-01-2004 01:42 PM
Tags
2002, 2005, 2006, adjust, adjusting, adjustment, brake, break, cable, civic, element, emergency, honda, nsx, odyssey, parking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
