options for ecu tuning PCT-003 ecu jun
Old 02-12-2006, 09:17 AM
jspecjoe's Avatar
Default options for ecu tuning PCT-003 ecu jun
http://putfile.com/pic.php?pic...&s=x7
here is the link to the pic its the ecu from my type r civic what are the options to chip the ecu etc. I have a new hondata s200 . I also use a harness to connect to the wiring harness.
Old 02-12-2006, 01:48 PM
jspecjoe's Avatar
wow popular post is this answered already I looked in history couldnt find anything ?
Old 02-12-2006, 01:56 PM
JjuuN R's Avatar
Default Re: options for ecu tuning PCT-003 ecu jun (jspecjoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jspecjoe &raquo;</TD></TR><TR><TD CLASS="quote">http://putfile.com/pic.php?pic...&s=x7
here is the link to the pic its the ecu from my type r civic what are the options to chip the ecu etc. I have a new hondata s200 . I also use a harness to connect to the wiring harness.</TD></TR></TABLE>
Type R Civic? hardly... wtf is your question?? what are you trying to find out?
Old 02-12-2006, 02:17 PM
jspecjoe's Avatar
well I wont argue the Type R status with you but if you read the post I ask what are my tuning options . Can I chip this ecu ? should I buy a p28 etc. I need opinions not criticism.
Old 02-12-2006, 05:45 PM
RagingAngel's Avatar
Default Re: (jspecjoe)
I dunno about the rest of you.....
but the link doesn't work for me.... as in I can't see the picture when I click on it.
Old 02-12-2006, 07:51 PM
jspecjoe's Avatar
its just a photo of the ecu so you can read the code on it. Do you know if hondata can chip this? should I use another ecu?
Old 02-13-2006, 01:09 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jspecjoe &raquo;</TD></TR><TR><TD CLASS="quote">its just a photo of the ecu so you can read the code on it. Do you know if hondata can chip this? should I use another ecu?</TD></TR></TABLE>
Let me help jOo work the interw3b and excercise clarity....
If the image cannot be shown....the code is:
37820-PCT-003 (first row)
1115-100161 (2nd row)
UU (in the bottom right hand corner)
And no....hondata cannot "chip" that particular ecu. You need something OBDI.
PR3, P30, P06, P28, P72 etc. In no particular order....though the P06 and P28s are cheapest as they are most plentiful...but then you need a harness adapter.
Or jOo can spend a lot of moolah and get something like this:
http://www.hondata.com/accessories.html
Old 02-13-2006, 03:14 PM
jspecjoe's Avatar
thanks I am going to use the p28 I guess I used it for my b series civic swap and it worked just fine.
Old 02-16-2006, 08:43 PM
confidence's Avatar
try for a p30 (jdm) or p72. they both have knock sensors the p28s do not. you can add a knock board from an ecu that has one but its a bit more work than i suspect you want to deal with.
hatchsiturbo
Honda CR-V & Element
10-20-2023 08:16 AM
1weakSi
Engine Management and Tuning
07-12-2010 05:23 PM
Unreal
08-25-2005 11:17 AM
TerribleOne
12-17-2003 09:40 AM
sydag5
12-22-2002 09:00 AM
Quick Reply: options for ecu tuning PCT-003 ecu jun
