Oil Pan Gasket with Hondabond????????
Old 04-11-2005, 03:08 PM
ITR-00-1457's Avatar
Default Oil Pan Gasket with Hondabond????????
Are you supposed to use hondabond on the oil pan gasket? It does not say to in the Helms manual, but Len told me today that you should between the oil pan and the gasket, and not between the oil pan and the block. I have changed the gasket before and never used hondabond and it has never leaked. But now my motor is leaking like a civ and it is either the oil pan gasket or the rear main seal. There is definately oil around the oil pan, but it is only dripping from underneath the rear main. But there is also oil all over the bottom of the motor/suspension from it being blown around.
So hondabond or no??????
Old 04-11-2005, 03:12 PM
Opie's Avatar
I use it on my valve cover gasket. I put a few touches on the corners. If you use it, don't glob it. Small little dabs.
I've never changed my oil pan gasket, it's due.
Old 04-11-2005, 03:14 PM
Chris F's Avatar
Default Re: (opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote">I've never changed my oil pan gasket, it's due.</TD></TR></TABLE>
What? You don't have to change it unless you drop the pan, right?
Old 04-11-2005, 03:18 PM
Opie's Avatar
Default Re: (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
What? You don't have to change it unless you drop the pan, right?</TD></TR></TABLE>
I was under the caR last week and noticed that it was beginning to leak. Lots of crap and oil building up on the sides of the pan.
Old 04-11-2005, 03:20 PM
MattD@Stoptech's Avatar
Default Re: (opie)
check the bolts...they are prolly l00se...the gasket itself doesn't go "bad", the bolts/nuts have a tendency to l00sen up over time....assuming the oil is, indeed, coming from the pan.
Old 04-11-2005, 03:21 PM
Opie's Avatar
Default Re: (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">check the bolts...they are prolly l00se.</TD></TR></TABLE>
ok, will do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">...assuming the oil is, indeed, coming from the pan.</TD></TR></TABLE>
STFU! "P
Old 04-11-2005, 03:23 PM
Chris F's Avatar
Default Re: (opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote"> STFU! "P</TD></TR></TABLE>
Dude, he didn't open the ****, I don't think.
Old 04-11-2005, 03:25 PM
thanks for jacking my thread Opie, j/k. but seriously what about my question? My bolts are not lose.
Old 04-11-2005, 03:26 PM
Default Re: (opie)
j00r fingers too fat to hit the right keys? j00 need a dialing wand?
Old 04-11-2005, 03:27 PM
Chris F's Avatar
Default Re: (ITR-00-1457)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR-00-1457 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for jacking my thread Opie, j/k. but seriously what about my question? My bolts are not lose.</TD></TR></TABLE>
Does the Hondabond do anything more than hold the gasket in place during installation? Maybe you got yours pinched in there or it wiggled out of place.
Old 04-11-2005, 03:40 PM
Does the Hondabond do anything more than hold the gasket in place during installation? Maybe you got yours pinched in there or it wiggled out of place. </TD></TR></TABLE>
sure it makes a seal, and does not let ot escape. it is what holds the oin in your motor and tranny.
Old 04-11-2005, 04:21 PM
rustyhatch's Avatar
i have used this stuff called "gaskaginch" with great sucess on nissan oil pans that just wont hold the op gasket for more than a few weeks. keeps the gasket from walking out on you.
Old 04-11-2005, 05:23 PM
Art Vandeleigh's Avatar
Default Re: Oil Pan Gasket with Hondabond???????? (ITR-00-1457)
my 2001 accord had a bad oil pan gasket and was replaced under warranty and they used a ton of hondabond around the new oil pan gasket. but i would be careful and not use too much as some of it could squeeze into the pan itself.
Old 04-11-2005, 06:01 PM
PatrickGSR94's Avatar
I would not use any. I've heard too many stories of Hondabond on the oil pan gasket not allowing the gasket to make a perfect seal and thus causing a worse leak than what you started with. Also it's VERY VERY VERY important to torque everything in steps and in sequence, so as to not warp anything or deform or flatten any part of the gasket unevenly, which could also cause more leaks.
Old 04-11-2005, 06:26 PM
Default Re: Oil Pan Gasket with Hondabond???????? (PatrickGSR94)
well guys I solved the problem, it was not the rear main seal, there was some material from the old gasket that I missed still left on the block, I removed it and put the gasket back on, without any hondabond and it seems to be all good, no oil dripping.
94 IntegraLS
05-07-2013 11:42 AM
phelpsj2
03-09-2010 12:16 PM
TypeRod
09-17-2009 06:32 AM
miro_gt
06-24-2007 08:02 AM
S13 slide
08-22-2002 08:37 AM
Quick Reply: Oil Pan Gasket with Hondabond????????
