oil leak at PCV black box: how do i fix it? - Honda-Tech
Old 10-07-2004, 02:57 PM   #1
euclid's Avatar
Default oil leak at PCV black box: how do i fix it?
i have a very rapid oil leak (about a quart every hundred miles) coming from the black box on the back of the block.
it is completly bolted in correctly so i dont know why it started leaking, and i dont know how to fix it.
can i remove it completely and cap the hole somehow, i was planning on doing a catch can soon but if i can somehow remove the entire PCV system it would help me at the moment, please lmk if anyone has had this problem. thanks
euclid is offline   Reply With Quote
Old 10-07-2004, 02:59 PM   #2
12 Years Strong
RobbieG35's Avatar
Default Re: oil leak at PCV black box: how do i fix it? (euclid)
I would try using an oil catch can
RobbieG35 is offline   Reply With Quote
Old 10-07-2004, 03:01 PM   #3
euclid's Avatar
Default Re: oil leak at PCV black box: how do i fix it? (HybridHatch88)
its leaking from the large hole in the back of the block where the black box fits, not the valve.
Old 10-07-2004, 03:01 PM   #4
DutchITR1689's Avatar
Mine is leaking on the top (PCV hose connection). No big deal yet.
DutchITR1689 is offline   Reply With Quote
Old 10-07-2004, 03:03 PM   #5
Quote:
Remove the box and replace the gasket.
Old 10-07-2004, 03:13 PM   #6
66.116.69.217
Default Re: oil leak at PCV black box: how do i fix it? (DutchITR1689)
yea its the gasket . I got mine replaced and no leaks anymore...try using some hondabond with the new rubber gasket
MR Dan is offline   Reply With Quote
Old 10-07-2004, 03:21 PM   #7
euclid's Avatar
Default Re: oil leak at PCV black box: how do i fix it? (DP24)
pic from RacingAngel
its leaking from the large hole that the breather box goes into
ill get a new gasket for it, what a pain in the *** it ill be to change that, can anyone confirm that i have to remove the intake manifold and the black support bracket to remove the breather box? thanks
Old 10-07-2004, 03:53 PM   #8
Rob Dizzle's Avatar
on my old motor i had the same problem with the o-ring leaking.
i didnt have the intake manifold support on their anymore so it was kinda painless taking it out.
im pretty sure its 3 bolts, and the lower one is also for the header support.
also make sure the 2 grommets on top of the pcv box arent leaking either. they get hard over time and dont seel (sp?)
just budget an hour or so from time you drive the car into the garage, jack it up then get it all finished.
Rob Dizzle is offline   Reply With Quote
Old 10-07-2004, 08:16 PM   #9
euclid's Avatar
Default Re: oil leak at PCV black box: how do i fix it? (Bob-DC2)
thanks, i am looking into the endyne breather kit, i will knock it all out at once.
ill try to do how-to on the process, with pics.
the gasket probibly failed from too much crankcase pressure as it is, the stock system is apparently insuffient for a modified motor.
sucks though, i bought a case of oil tonight to keep up with the leak.
weber swap ?s LazloZ28 Classic Hondas 1 08-22-2013 09:54 PM
pcv problems plz help 91teg6908 Forced Induction 1 10-26-2010 08:39 AM
Oil in intake, clogged PCV? so simple Tech / Misc 5 05-12-2010 12:49 AM
Vac leak, adjusting idle? MidwestCivic Tech / Misc 1 06-25-2007 09:37 PM
clogged pcv, oil seals, and oil leaks 1.8T_EG Forced Induction 4 07-30-2004 08:31 AM
Tags
black, blackbox, box, breather, change, civic, connection, fix, h22, honda, integra, leak, leaking, oil, pcv
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
