Motul Engine Oil
Old 11-06-2003, 10:08 AM
  #26
rtype11's Avatar
Default Re: Motul engine oil ?? (HypeR1004)
no im positive got a hook up at my friends shop we get 300V in 1litre tins for about 5USD when we order enough.
Old 11-07-2003, 07:59 AM
  #27
bcrl's Avatar
Default Re: Motul engine oil ?? (rtype11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtype11 &raquo;</TD></TR><TR><TD CLASS="quote">no im positive got a hook up at my friends shop we get 300V in 1litre tins for about 5USD when we order enough.</TD></TR></TABLE>
Sounds good
Old 11-07-2003, 08:10 AM
  #28
New User
RaVAGE00's Avatar
Group Buy.
Old 11-07-2003, 03:44 PM
  #29
bcrl's Avatar
Default Re: Motul engine oil ?? (RaVAGE00)
Group buy sounds good
Old 11-07-2003, 06:57 PM
  #30
bcrl's Avatar
Default Re: Motul engine oil ?? (bcrl)
Anyone?
Old 11-08-2003, 06:42 AM
  #31
New User
RaVAGE00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bcrl &raquo;</TD></TR><TR><TD CLASS="quote">Anyone?</TD></TR></TABLE>
I am in....
I have a question - I use Motul 8100, like it allot, however, why is 300v better.... what is the difference between the ester based 300v and the 8100??? I thought the 8100 is fully 100 % synthetic...
Old 11-10-2003, 04:18 AM
  #32
New User
RaVAGE00's Avatar
anyone?
Old 02-10-2004, 04:03 PM
  #33
sesshona's Avatar
300v has higher shear strength and more additves in it i think. 8100 e-tech is also ester based, which is what i use in my bmw. 8100 will last a lot longer under street conditions.
Old 02-10-2004, 05:35 PM
  #34
XenonDepot's Avatar
I get mine from http://www.speedstar.ca
Old 02-10-2004, 05:46 PM
  #35
Dr Pooface's Avatar
Default Re: Motul engine oil ?? (XenonDepot)
I use 300v in my turbo R. Seems to burn less than anything else I've tried, but it is a bit expencive.
I'd be in for a group buy for $5 a liter. I'd buy 20.
Old 02-12-2004, 06:37 AM
  #36
Footwork's Avatar
im running the 300v chrono - great stuff.
it stays golden in color much longer than mobil1.
Old 02-12-2004, 06:41 AM
  #37
.RJ
.RJ's Avatar
Default Re: Motul engine oil ?? (Primo.)
I would be interested in trying this stuff out, but its really pricey...
http://ltbmotorsports.com/motracoil.html
Where are you guys getting this stuff for $5/liter?
Old 02-12-2004, 06:47 AM
  #38
Footwork's Avatar
Default Re: Motul engine oil ?? (.RJ)
The 300V Chrono 10w40 I run comes in those square type cans - i think it's 1 liter which is about 2.1 quarts.
It's weird tho because you need to put more than 2 cans in.
I guess the conversion is off.
Anyways, if the wrong guy is working where I go it's $19/can. =P
Old 02-12-2004, 06:49 AM
  #39
.RJ
.RJ's Avatar
$50 oil changes are too much for me.
Old 02-12-2004, 07:26 PM
  #40
ejprimo's Avatar
1 quart = .946 liters
Old 02-12-2004, 07:38 PM
  #41
Spikey's Avatar
Default Re: Motul engine oil ?? (ejprimo)
good luck getting 300V at $5 a liter
having seen the dealer pricing sheets, i can tell you that's impossible, even with a group buy
Old 02-12-2004, 11:35 PM
  #42
kool168's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaVAGE00 &raquo;</TD></TR><TR><TD CLASS="quote">
I have used Mobil 1 5w30 from day one after the Honda installed oil was drained when the R had 3 km's on her. I switch to Motul 8100 5w40 about 5 months ago, seems the engine idle is a tad less noisy.... You will notice straight away the differences as far as how Motul looks and smells...
I like it... so I will stick with it.... but it can get a bit pricey.... especially the 300v at 35.00 Canadian for 2 Liters.
wow $35 for 2 liters? that's cheap man
mobil 1 is $27 plus tax, it's only $8 different... good deal
do you wanna share where do you buy the motul for 35?
Old 02-13-2004, 12:50 AM
  #43
bcrl's Avatar
Default Re: Motul engine oil ?? (SOL-R)
Mobil 1 (2L) $27 CAD or US?
Maybe you're talking about "Mobil 1" 4L packing.
Old 02-13-2004, 04:29 AM
  #44
New User
RaVAGE00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOL-R &raquo;</TD></TR><TR><TD CLASS="quote">
do you wanna share where do you buy the motul for 35?</TD></TR></TABLE>
SpeedStar - Speak with Albert - http://speedstar.ca/main_contactus.htm
Old 02-13-2004, 07:09 AM
  #45
gaskleppie's Avatar
300V is better for boosted engines
1800V is better for street or NA engines
What is more expensive? A few liters of oil, or a fucked up engine? You chose!
Old 02-13-2004, 07:13 AM
  #46
.RJ
.RJ's Avatar
Default Re: (gaskleppie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gaskleppie &raquo;</TD></TR><TR><TD CLASS="quote">What is more expensive? A few liters of oil, or a fucked up engine? You chose!</TD></TR></TABLE>
$25/liter, that would be $125 per oil change, budget for some consumption along the way.
Say you expect to get 120,000 miles out of your engine. Thats reasonable, no?
Say you change the oil every 3750 miles (honda recommendation).
Thats 32 oil changes... A 5qt Jug of Mobil 1 or Syntec will cost $20. Thats $3360 over the life of the engine....
Enough to buy a new crate motor from honda.
*shrug*
Old 02-13-2004, 07:20 AM
  #47
Footwork's Avatar
Default Re: (.RJ)
comparing mobil1 to motul 300v, i noticed that the motor runs much smoother and quieter with the motul.
then again i was running 5w30 mobil and now 10w40 motul.
also my crate engine would fry the mobil1 a lot faster, so i had to change it a lot more often to keep the color golden.
the motul stays golden much longer.
i still want to try redline again tho.
Old 02-13-2004, 07:26 AM
  #48
.RJ
.RJ's Avatar
Default Re: (Primo.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Primo. &raquo;</TD></TR><TR><TD CLASS="quote">the motul stays golden much longer.</TD></TR></TABLE>
Were you sending the oil off for analysis?
Old 02-13-2004, 07:40 AM
  #49
gaskleppie's Avatar
Default Re: (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
*shrug*</TD></TR></TABLE>
IF your engine holds on to 120.000miles!
In Holland you can buy only a new block for $3360. If you need a head also, you've got a problem!
Old 02-13-2004, 07:41 AM
  #50
.RJ
.RJ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gaskleppie &raquo;</TD></TR><TR><TD CLASS="quote">IF your engine holds on to 120.000miles!</TD></TR></TABLE>
That should be the minimum for a properly maintained engine.
A high stress, high rpm engine (ITR motor, E30 M3 motor, E34 M5, etc, etc) probably will not last 150-200K when driven hard.
Quick Reply: Motul Engine Oil
