Minimum Battery Voltage to Start Car? - Honda-Tech
Old 03-16-2003, 12:23 AM   #1
WTypeRogerX's Avatar
Default Minimum Battery Voltage to Start Car?
What's the minimum battery voltage to start the R? Or is it amps? I'm not sure if I can measure the amperage of the battery with a voltmeter. My battery may be going bad because it's such a garage queen, but I'd like to know whether I can bother to attempt to start my R the next time, or just charge the battery. I'm getting 12.55 volts fully charged. Are you guys with stock batteries getting higher voltage? My WRX is 12.78 volts, but it has a much bigger battery.
WTypeRogerX is offline   Reply With Quote
Old 03-16-2003, 01:35 AM   #2
Default Re: Minimum Battery Voltage to Start Car? (WTypeRogerX)
From the Car Battery FAQ below, 12.55v is approx. 90% fully charged.
http://uuhome.de/william.darden/carfaq4.htm
dax-es is offline   Reply With Quote
Old 03-17-2003, 10:03 AM   #3
vtec.dc2's Avatar
i think it amps and depends on the weather, - why my stock battery died, it showed signs before it dropped to cold temps (lights dimming in/out), it measured at ~ 360cca and would not start the car in cold weather.
vtec.dc2 is offline   Reply With Quote
Old 03-17-2003, 10:14 AM   #4
jond's Avatar
I would guess 9 volts would probably start it. 10 volts definatly would.
jond is offline   Reply With Quote
Old 03-18-2003, 12:39 AM   #5
GDD 1%
Rtzx9r's Avatar
Default Re: Minimum Battery Voltage to Start Car? (jond)
9-10 volts equals 1 bad cell in your battery.
Voltage does not really matter, it is the AMPS that deliver the power to start the car.
All the stuff inyour house runs on 120volts, but the big stuff, like your blender, furnace, etc draw far more current (amps) at the same voltage. voltage=amps*resistance.
I don't know the exact # for req'd amps in your battery to start your car, but you should be ok w/ 12.5 I think. Check w/ the voltmeter when the car is running across the terminals of the battery- it should be reading 13-14 volts because it is charging.
If not, replace the battery or alternator. (at a shop if you are not sure even on how electricity works) Batteries are like 50 bucks.
Rtzx9r is offline   Reply With Quote
Old 03-18-2003, 02:11 AM   #6
YellowKahuna's Avatar
how about just enough to get a spark
YellowKahuna is offline   Reply With Quote
Battery not being charged POLISHH22 Honda Prelude 9 08-22-2015 08:38 AM
You Got A Battery Light GoodUsername Honda Accord (1990 - 2002) 8 06-01-2015 02:47 PM
No voltage at radiator fan Schultzie Honda Civic / Del Sol (1992 - 2000) 11 07-18-2010 07:11 AM
battery voltage BigIslandBoi Honda Civic / Del Sol (1992 - 2000) 6 08-22-2006 10:50 PM
Car steadily loses voltage when the car gets really hot? WTF? beef-cake Tech / Misc 9 06-08-2006 08:38 AM
Tags
1255, 1255v, amps, battery, car, charge, depends, min, minimal, minimum, start, starting, voltage, volts, weather
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
