JDM Front...t-bar or whole rad support, what's stronger?
Old 08-18-2010, 01:31 PM
jsk62's Avatar
Default JDM Front...t-bar or whole rad support, what's stronger?
Yes, I've searched. I read through a million jdm front threads but none of them really talked extensively on this topic.
We know there are 2 ways to do the radiator support for a conversion. You can drill the spot welds and do the entire support and reweld the whole thing to the car frame, or you can opt to just do the "t-bar" and keep the lower factory welds.
I'm very aware many of you are against cutting a perfectly good itr up for the sake of a conversion, but let's try to keep that aside for now.
Which method will retain the most structural rigidity? Cutting the t-bar off from the bottom of the radiator support essentially cutting the radiator support in half, and rewelding just the top piece, or keeping the radiator support as a whole and welding the whole thing to the frame?
I'm inclined to think that keeping the lower welds would keep the car stronger b/c the t-bar doesn't seem to be as much of a lateral load bearing structure. Its primary design seems to focus more on just holding the headlights and keeping the hood latched.
What's your opinion on this and why?
Old 08-18-2010, 05:39 PM
00-1065's Avatar
Default Re: JDM Front...t-bar or whole rad support, what's stronger?
Id say the t-bar mod will be stronger because you are keeping the lower factory spot welds in place.
Old 08-18-2010, 05:53 PM
NecroFIesh's Avatar
^^, then again...depending on the year of the car, (IE:2001) that means the factory welds would be 9 years old at least...wouldn't newer welds be (in theory) stronger than say 9 year old welds? or say the car is from '97 when the ITR debuted in the US...those welds would be 13 years old now...just sayin...
Old 08-18-2010, 06:17 PM
powerfulperformance's Avatar
Do it the t-bar way because its easier and stronger. Why take out the whole support when u don't have to...
Here is mine......
Old 08-20-2010, 03:02 PM
NecroFIesh's Avatar
word, looks good man. get some paint on that thing!!
Old 08-20-2010, 03:05 PM
Pr-Type-R's Avatar
i also did the T bar and it is perfectly strong
Old 08-20-2010, 04:12 PM
NecroFIesh's Avatar
x2 on the T-bar route, anyone else
Old 08-20-2010, 06:26 PM
Its already painted, check my itr rebuilt thread...
Old 08-20-2010, 06:47 PM
HeLLa iLL2ndGen's Avatar
This is a good info
scribecity's Avatar
Location: A little town called none of you god damn business!
T bar for sure
Old 08-20-2010, 10:31 PM
exotik4doorcivic's Avatar
the way in the pic is the same way i did mine.
Old 08-20-2010, 10:38 PM
cibao2ner's Avatar
since u guys are on topic...where can i buy just the t-bar or a jdm rad support...its all im missing for my front...
Old 08-21-2010, 05:35 AM
coolhandluke's Avatar
What is a stronger setup? Retaining the USDM core support and just swapping the JDM T-bar. What is the better or best method for a JDM front? That's for you to decide.
Old 08-21-2010, 07:40 PM
Check your local jdm warehouses, ebay and honda-tech classifieds....
ev0luti0n
04-19-2004 04:37 AM
ev0luti0n
04-18-2004 08:41 AM
kappa
10-25-2002 02:23 PM
euroturbo-R
07-11-2002 05:48 PM
ImprtTunr
12-16-2001 02:18 AM
Quick Reply: JDM Front...t-bar or whole rad support, what's stronger?
