installed Kenji p28 ecu and threw 2 codes?
Old 10-16-2002, 05:27 PM
jonas's Avatar
Default installed Kenji p28 ecu and threw 2 codes?
uhh, before when i was running the regular p73 ecu.. i was only throwing a knock code.
so i opted for a p28 to get rid of the knock sensor period..
now its throwing 21 and 22, which is:
VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve
* invalid code for non-VTEC engine
** invalid for V6 engine
VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch
any help?
Old 10-16-2002, 05:30 PM
EleanoR's Avatar
Default Re: installed Kenji p28 ecu and threw 2 codes? (jonas)
If i were you i would just contact Kenji again. He is a stand up guy from what i hear and will help you sort out the mess
mike
Old 10-16-2002, 05:59 PM
sgT
sgT's Avatar
Default Re: installed Kenji p28 ecu and threw 2 codes? (EleanoR)
try a known good harness adapter.
Old 10-16-2002, 06:01 PM
jonas's Avatar
Default Re: installed Kenji p28 ecu and threw 2 codes? (sgT)
i also have kenji's obd1 conversion harness... if that's what you meant?
Old 10-16-2002, 06:03 PM
sgT
sgT's Avatar
so try ANOTHER one.
whether it be skunk2, or another generic
Old 10-16-2002, 07:36 PM
CRVRX's Avatar
Why wouldn't you contact Kenji before telling to world you have a problem. Give the guy a chance to fix it before you start asking questions.
Give Kenji a call !
Old 10-16-2002, 07:40 PM
jonas's Avatar
Default Re: installed Kenji p28 ecu and threw 2 codes? (CRVRX)
i already did, and i'm didn't blame Kenji at all..
so start READING before you assume
i was wondering if maybe I did something wrong.. or there was something i was unaware of while converting from obd2 -> obd1.
Kenji already replied and told me to send it back to him and he'll take a look at it and try to get this resolved ASAP
Kenji and customer service
[Modified by jonas, 8:42 PM 10/16/2002]
big strong guy
rainmanEK's Avatar
nothing big i presume, perhaps accident? He will stand by his word!! eric
Old 10-16-2002, 07:42 PM
hybridtuner's Avatar
Kenji is a good guy (been friends for a few years). he will make it all good if he messed it up. just contact him
jonas's Avatar
Old 10-16-2002, 09:11 PM
jonas's Avatar
ok, now Crescent from c-speed says it could be due to my JDM Vtec solenoid?
Old 10-16-2002, 09:20 PM
BoostedGSRBubble's Avatar
what program does kenji use?
I dont buy the jdm vtec solenoid. Its the same as usdm as far as the wiring goes, just look in a helms. I have a jdm b18c and no codes w/ a katman chipped p28. Its a knockoff mugen program, thats why I asked what kenji uses. The only varible being im obd1 all the way around.
[Modified by trustsi, 6:23 AM 10/17/2002]
Old 10-16-2002, 09:21 PM
YumVTEC's Avatar
most likely in your obd2 --> obd1 harness. i ran a p73 ecu in my ek with my b18c5 with no codes, then installed a chipped p28 with a home-made obd2 --> obd1 harness and had no problems.
Old 10-16-2002, 10:25 PM
sgT
sgT's Avatar
You cant use the JDM solenoid since it has no oil pressure switch.
So there is one code explained. The other code is still probably in
the wiring somewhere.
Old 10-17-2002, 12:28 AM
pinota's Avatar
Euro ITR don´t have the oil pressure switch in the VTEC solenoide assy.
You have make a custom harness for your car, you´ll need to connect the pressure switch wire in the back of the block to the oil pressure switch in the ECU.
Old 10-17-2002, 02:27 AM
kenji's Avatar
Thanks sgt for clearing up the fact that the JDM VTEC solenoid does not have a VTEC pressure switch. This would lead to a code 22.
As for the code 21, I seriously doubt it is in my harness. I checked it three times before I sent it out.
I was not aware of the fact that Jonas was running a JDM VTEC solenoid. So, when he emailed me stating he is throwing codes I was GREATLY concerned.
I have read about, but have not tried, the little 'fix' for USDM ECUs using a JDM VTEC solenoid. I read in a previous post that you can connect the VTEC PS and VTEC solenoid wires with a jumper and that will solve the problem associated with the JDM VTEC solenoid not having a pressure switch. Does anybody know if this is true from experience?
Jonas, don't worry. I will solve this problem for you. Thanks for your patience.
-kenji
Old 10-17-2002, 04:03 AM
Stumpy's Avatar
Default Re: installed Kenji p28 ecu and threw 2 codes? (kenji)
Old 10-17-2002, 12:03 PM
jonas's Avatar
Thanks again Kenji.. I was never worried dealing with you
Old 10-17-2002, 06:04 PM
Cosworth's Avatar
Kenji
Old 10-17-2002, 06:47 PM
tonyxcom's Avatar
Default Re: installed Kenji p28 ecu and threw 2 codes? (Cosworth)
Kenji
In my dealings with Kenji, he has always been a pleasure to deal with, not that you guys dont already know that, but for anyone who hasn't had the pleasure.
Old 10-17-2002, 07:25 PM
Dave-ROR's Avatar
Default Re: installed Kenji p28 ecu and threw 2 codes? (tonyxcom)
see sig for my opinion of kenji
Old 10-17-2002, 09:43 PM
YumVTEC's Avatar
Default Re: installed Kenji p28 ecu and threw 2 codes? (Dave-ROR)
Never done business with you Kenji, but I must say your reputation is phenomenal. Keep up the good work bro.
Old 10-17-2002, 09:50 PM
AzN_Flava's Avatar
Default Re: installed Kenji p28 ecu and threw 2 codes? (YumVTEC)
hmmm i tried to IM kenji but it doesnt work, so anyways,
What is this chipping supposed to do?
how much does he charge?
From what im reading, this guy has great customer service.
Old 10-17-2002, 10:17 PM
giooooo's Avatar
does anyone know about a p08 ecu? help me out here
https://honda-tech.com/zerothread?id=309862
Old 10-18-2002, 02:56 AM
kenji's Avatar
Default Re: installed Kenji p28 ecu and threw 2 codes? (AzN_Flava)
AzN_Flava,
Email me for information regarding chipping your ECU. I don't want to turn this post into an advertisement. Thanks.
-kenji
Quick Reply: installed Kenji p28 ecu and threw 2 codes?
