how to remove nasty bugs stain & stone chips??
Old 09-10-2002, 08:47 AM
Anderson's Avatar
Default how to remove nasty bugs stain & stone chips??
how do you guys remove nasty bugs stain and small stone chips from your front bumper without leaving marks??
i have some nasty bug stain in my CW paint job now
what kind of wax or cleaning products should i use?
Old 09-10-2002, 08:57 AM
Willard's Avatar
Default Re: how to remove nasty bugs stain & stone chips?? (Anderson)
lemon scented soft scrub....
use on a wet rag and do not use much pressure...
clean and then wax.
Old 09-10-2002, 09:18 AM
ITR764's Avatar
Default Re: how to remove nasty bugs stain & stone chips?? (Willard)
replace front end as needed (it's a wear item)
Old 09-10-2002, 10:12 AM
Bbasso's Avatar
Default Re: how to remove nasty bugs stain & stone chips?? (ITR764)
I think it might actually be... 30k miles and mine looks like it went thru a rock war.
Old 09-10-2002, 10:13 AM
I shoot brides
yoshi234's Avatar
I took mine off, sanded it down and repainted in the garage
Old 09-10-2002, 10:14 AM
MPH
New User
MPH's Avatar
Bugs come off easy with Armor All - All Purpose Cleaner. This stuff will get anything off.
Old 09-10-2002, 10:21 AM
Black R's Avatar
.....www.carcareonline.com
check the how-to/ faq's...
Old 09-10-2002, 10:23 AM
Big Phat R's Avatar
2500 psi of pressure washer should get that out (paint too but who cares).
Old 09-10-2002, 10:25 AM
ITR764's Avatar
Default Re: how to remove nasty bugs stain & stone chips?? (Bbasso)
same here and some track events and it looks like azz . fuq it, that's why i never look at the front anyway...
Old 09-10-2002, 01:03 PM
Anderson's Avatar
Default Re: how to remove nasty bugs stain & stone chips?? (MPH)
so is okay to use the all purpose cleaner on the paint job??
it looks like the bug stain has gone into my cw paint
Old 09-10-2002, 01:04 PM
TsunamiZC's Avatar
clay bar
Old 09-10-2002, 01:48 PM
Bloodwynch's Avatar
Default Re: how to remove nasty bugs stain & stone chips?? (tsunami_zc)
clay bar
Correctumundo!
Old 09-10-2002, 04:09 PM
ee-gsr's Avatar
after collecting about 200+ insect parts on my front bumper (taffeta white) during a recent drive to socal and letting it all bake on for another week thereafter i did the following:
1. hose down the car with water
2. i use Meguiar's Gold car wash liquid and applied a good layer of it to all the spots that i knew would be a pain and let it sit for a good 10 min
3. with a moist/saturated sponge, scrub those persistent spots until they go away
4. wash off and rewash again with the rest of the car and hopefully all will be good again.
don't forget to wax afterwards.
for rock chips, touch up paint. for the really microscopic ones that show up on white paint if u look really closely, just let it be.
Old 09-10-2002, 06:37 PM
2000 Integra R #760's Avatar
clay bar
Perfect for that stuff!
Old 09-10-2002, 06:46 PM
ee-gsr's Avatar
Default Re: how to remove nasty bugs stain & stone chips?? (2000 Integra R #760)
does the clay bar leave any residue or other deposits afterwards? can u get it at any car products store like autozone or kragen?
Old 09-10-2002, 06:52 PM
BRICKHEAD's Avatar
Bug and tar remover works wonders. Circular motion until all is gone. Then rubbing compound, then 3M handglaze or wax either way should look great with little time spent.
Old 09-10-2002, 07:15 PM
R1525's Avatar
Default Re: how to remove nasty bugs stain & stone chips?? (JDM-R)
mother's clay bar may be bought at local kragen or you can check out http://www.zaino.com for their clay bar. either will do. you should be able to remove the bug stains by spraying it for some time to soften it up.
Old 09-10-2002, 10:20 PM
LiKe_WhOa!'s Avatar
Default Re: how to remove nasty bugs stain & stone chips?? (R1525)
how about bird ****? how do i get that out?
Old 09-10-2002, 10:26 PM
MK Ultra's Avatar
I think this would do it.
[Modified by MK Ultra, 1:28 AM 9/11/2002]
Old 09-11-2002, 01:02 AM
vtecdc2's Avatar
Default Re: how to remove nasty bugs stain & stone chips?? (MK Ultra)
why would any idiot do that???
Old 09-11-2002, 01:56 AM
shit post warrior
ITRbroham's Avatar
Default Re: how to remove nasty bugs stain & stone chips?? (VTECDC2)
Interesting way to fix stone chips: http://www.s2ki.com/forums/showthrea...threadid=62790
Old 09-11-2002, 04:58 AM
MPH
New User
MPH's Avatar
Yes, it's safe. I been using it on my R and civic for 2 years with no problem.
[Modified by MPH, 4:37 PM 9/11/2002]
Old 09-11-2002, 09:26 AM
Rob Dizzle's Avatar
not sure about the stone chips
but I DO KNOW how to get bug stains out.
1. start with a good soap; you wont get the stain off with this, its just helps to have the bug guts with some water on them
2. a cleaning wax, not a polishing/shine wax. I use either meguires #6 cleaner/wax or go with zaino bros. if its a really bad stain then do 2 stages, apply wax on and let it sit, then take off with terry cloth towel, repeat steps
make sure you are using either a soft applicator pad, or 100% terry cloth towel
i would not recomend a clay bar. they are designed for taking off a thin film of grit on your car, and taking off the wax that was their before. so when you put new wax on, it will have a proper surface to stick to
Old 09-11-2002, 11:33 AM
RealTypeR2's Avatar
Default Re: how to remove nasty bugs stain & stone chips?? (bob46802)
I take my car to the do it yourself car wash and use the pressure washer to clean the bumper off anfter I wash it. No problems at all. Just dont aim the nozzle really close.
Or I use HONDA SPRAY POLISH AND CLEANER. Does wonders and leaves a silky smooth babys *** finish to the bumper.
[Modified by RealTypeR2, 3:34 PM 9/11/2002]
Old 09-11-2002, 12:37 PM
SurferX's Avatar
I just don't understand that
Quick Reply: how to remove nasty bugs stain & stone chips??
