How much of the suspension is covered under extended warranty? - Honda-Tech
Old 02-09-2004, 12:03 PM   #1
Default how much of the suspension is covered under extended warranty.
For a while now my car has been making an annoying whirringish sound when I turn the wheel all the way left or right and step on the gas. At first acura thought it was the steering column so they lubed it but it still made the noise. I took it in and took a tech with me to reproduce the sound and he said it was coming from the suspension. I'm sure it can't be my coilovers because the sound existed before I installed my coils. But they have been workign on the car since friday and still can't figure it out. So i'm jsut wondering if, chances are the problem will be a warrentied problem or am I going to be paying a grip to get rid of this sound?
RiCE On IcE 2 is offline   Reply With Quote
Old 02-09-2004, 02:27 PM   #2
ITR.#1446's Avatar
Default Re: how much of the suspension is covered under extended warranty. (RiCE On IcE 2)
if they do cover it let me know i bought my car with koni's on it and i put the seat down to transport something and i noticed my rear shocks were squeaking like they were blown just wondering if it was covered under waranty also.
ITR.#1446 is offline   Reply With Quote
Old 02-09-2004, 03:38 PM   #3
uNF$@#!'s Avatar
Default Re: how much of the suspension is covered under extended warranty. (ITR.#1446)
wear and tear isnt covered
now if its abnormal and theres evidence of it im sure they would cover...
but imo, extended warranties are for suckers when it comes to these cars...
why? because dealerships as soon as they see type R's run for the hills and deny claims left and right
uNF$@#! is offline   Reply With Quote
Old 02-09-2004, 05:12 PM   #4
Bbasso's Avatar
Default Re: how much of the suspension is covered under extended warranty. (Soup ****)
Quote:
Or you have to fight tooth and nail to get them to cover chit.
Bbasso is offline   Reply With Quote
Old 02-09-2004, 05:16 PM   #5
.RJ
.RJ's Avatar
Quote:
Konis = not factory item = not covered
.RJ is offline   Reply With Quote
Old 02-09-2004, 05:21 PM   #6
Default Re: how much of the suspension is covered under extended warranty. (.RJ)
I don't think it's a wear and tear item. And so far my acura has been pretty good about doing warranty work.. they did some past warranty too on good will. I guess I will have to wait till they figure out wtf the sound is.
Old 02-09-2004, 05:25 PM   #7
Quote:
Its probably a combination of the power steering and LSD.
Just trade the car in on something that doesn't make any noises, or has a lot of sound insulation so you can't hear them.
ZygSpeed is offline   Reply With Quote
Old 02-09-2004, 05:31 PM   #8
.RJ
.RJ's Avatar
Thats a judgement call up to the service advisor/manager/regional rep...
Old 02-09-2004, 05:34 PM   #9
Default Re: how much of the suspension is covered under extended warranty. (zygspeed)
no it's not a regular noise... no other ITR's I've been in make the sound even remotely
Old 02-09-2004, 05:41 PM   #10
If that's the case, then I'd be looking at your wheel/tire combo and suspension drop. It's not uncommon for the tire (depending on size and wheel type/offset) to rub the inner fender liner (I forget if its full lock right or full lock left). Which beggs the point that you shouldn't be keeping it at full lock anyway since its harder on the power steering pump ... and it rubs!
Old 02-10-2004, 12:36 AM   #11
it made the same sound on the stock width and stock drop too.. they checked if the azenis were rubbing and they weren't so I unno yet.
Old 02-10-2004, 10:02 PM   #12
Update:
After having acura spend about 3 days working on the car. A tech called around and was informed of another ITR making the same sound. The answer?... Flush the transmission fluid a few times. I guess there was gunk in there that made the gears make some funny sounds that vibrated to the suspension? Well the problem seems solved. Odd problem I guess?
Metal sound on start VFR Honda Accord (1990 - 2002) 6 08-17-2016 04:38 PM
Axle/Transmission Problem -- Videos Included -- Experts, Please Help! ParadoxTeg Acura Integra 13 08-08-2013 11:01 AM
ef2 suspension problem...!!! BiG ChOr!Zo Honda CRX / EF Civic (1988 - 1991) 52 09-01-2011 09:42 PM
Suspension Clunking? help Mr.Luder Honda Prelude 5 01-13-2007 04:43 PM
Help Exhaust Vibration 1.6 vtec civic Honda Civic / Del Sol (1992 - 2000) 6 07-18-2006 06:07 PM
Tags
acura, covered, extended, honda, power, pump, rear, shocks, steering, struts, suspension, suspensions, warranties, warranty, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
