how many quarts of mtf? - Honda-Tech
Old 01-17-2002, 09:45 PM   #1
Gump's Avatar
Default how many quarts of mtf?
i just changed my tranny fluid a couple of weeks ago, and resently i've been having trouble getting into reverse, someone told me that its because i did not put enough mtf (i put 2.5 quarts) so how much are you supposed to put?
[Modified by xlr8 si, 5:45 AM 1/18/2002]
Gump is offline   Reply With Quote
Old 01-17-2002, 09:57 PM   #2
sgT
sgT's Avatar
Default Re: how many quarts of mtf? (xlr8 si)
2.5 is more than enough
takes just over 2, like 2.2
sgT is offline   Reply With Quote
Old 01-17-2002, 10:21 PM   #3
B2FiNiTY's Avatar
Just a bit over 2.
B2FiNiTY is offline   Reply With Quote
Old 01-17-2002, 10:34 PM   #4
Gump's Avatar
Default Re: how many quarts of mtf? (sgT)
ok, if its only about 2.5 then why do i suddenly have a problem of getting into reverse? i have to go into first and second then reverse just so it will go in with ease. also one more question how many people put the new mtf through the hole where the vehicle speed sensor (v.s.s.) goes? thats where i put it and its a whole lot easier than through the bottom.
Old 01-18-2002, 09:44 AM   #5
R R
ur suppose to go into first gear then reverse to syn. the gears if u want to do a reverse..
r
R R is offline   Reply With Quote
Old 01-18-2002, 12:18 PM   #6
Gump's Avatar
Default Re: how many quarts of mtf? (RICKS R)
r
i never had to go into first before, till now.
Old 01-18-2002, 12:51 PM   #7
New User
i recently changed my mtf and i put in at least 2.5 quarts(thats how much it took before it started running out the top hole. i have been having some trouble lately getting into first too, i am wondering if i put in too much mtf. where is the speed sensor located?
albert butterbikini is offline   Reply With Quote
Old 01-18-2002, 02:24 PM   #8
forksports's Avatar
I think its a common problem for most honda trannys, I usually just put it in 1st then R....or release the clutch & press it again, try put into R again.
forksports is offline   Reply With Quote
Old 01-18-2002, 02:27 PM   #9
Default Re: how many quarts of mtf? (forksports)
You might have put too much, I think the actual spec is 2.2 quarts
I always just put 2 quarts
HX_Guy is offline   Reply With Quote
Old 01-18-2002, 03:25 PM   #10
New User
Because you forgot to open the garage door before trying to back out.
nsxtcjr is offline   Reply With Quote
Old 01-18-2002, 08:40 PM   #11
Gump's Avatar
Default Re: how many quarts of mtf? (typeR158)
on the top of the tranny near the charcoal canister can't miss it, it only has one nut holding it down
change mtf on del sol splashy Honda Civic / Del Sol (1992 - 2000) 8 04-06-2015 05:58 PM
b16 tranny flush????? cbabyby Tech / Misc 2 02-22-2010 02:27 PM
Transmission fluid IntegR Acura Integra Type-R 5 12-23-2006 10:11 AM
how much quart/bottle does b-series tranny take? wizzards581 Acura Integra 1 03-08-2004 10:33 PM
How much MTF is needed? REDBARON Tech / Misc 5 06-05-2002 11:17 AM
Tags
02, 91, add, civic, honda, integra, mtf, put, quart, quarts, sensor, si, speed, transmission, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
