how do you check for a clogged cat
Re: how do you check for a clogged cat (ITR21)
First you'll notice that they start getting fater and there won't be any poo in the litter box. After that, I say take it to a vet.
[Modified by AssPenny, 4:46 PM 10/9/2002]
Re: how do you check for a clogged cat (AssPenny)
Altough Asspenny's answer is correct , pretty much the only way to check is to remove the catalytic converter and look through one end to see if lt is clogged.
Re: how do you check for a clogged cat (JPP)
Yeah, you should be able to see though a catalytic converter when held up to a light. Atleast mine was like that brand new, dunno if it still works on a used one.
Paragraph Alert
From my experience you'll be cruising along just fine. Decide to hit VTEC and the car just bogs to death and won't take any gas. Limp it home so slow the speedometer isn't even registering because it won't take any gas.
hmmm my car is away for the winter right now and i had some problems with it. anyone know how to check injectors?
you probably have old broken down gas in the tank.
I dont know if you can add stablizer to gas that is already bad.
Try taking out the old gas and filling up with new. Throw in some Clean Power while you are at it.
With this tester you can check and balance fuel injectors. Also tests fuel injector coil windings under load; detects intermittent fuel injector coil faults; and features adjustable current output. Same as Kent-Moore J-39021-22.
Works on both throttle body (TBI adapter included) and multi-port fuel injectors.
Only $224 http://www.ontool.com/store/product/...1/7002/7002/-1
I could have, but my brain hurts to much... lack of sleep is a bumer....
Craig - Who stayed up late playing Kelly Slater Pro Surfer last night
You can also send your injectors to RC to have them cleaned and balanced since your car is not being used now.
http://www.rceng.com/service.htm
First you'll notice that they start getting fatter and there won't be any poo in the litter box. After that, I say take it to a vet.
Good one
