How to determine octane rating necessary for certain compression ratios?
Old 06-21-2002, 07:28 PM
sneakychaos's Avatar
Default How to determine octane rating necessary for certain compression ratios?
Maybe I'm just a confused soul, but I was trying to figure this out today. (See topic.) Say for example, you have a B18C5 setup and you bump compression to 12:1. Change the ECU to fuel cut / rev limit at ~9300... (is that even pertinant?) -- how do you determine the octane rating necessary to keep your engine safe/clean?
My first thoughts were FI applications. They cram the air in the combustion chamber, and typically run on pump gas. Using race gas they can add more boost... but, is there a difference for NA applications? Would 12:1 require a higher octane?
Perhaps I'm not asking the right questions... Assuming the car could run on 93 octane pump gas @ 12:1, would you typically make more power and be more efficient running say 100 octane?
Sorry if its drawn out... just trying to get a better understanding. Thanks in advance for the input.
Old 06-21-2002, 07:44 PM
Stumpy's Avatar
Default Re: How to determine octane rating necessary for certain compression ratios? (trooth)
No, you should run the lowest octane that doesn't ping.
Old 06-22-2002, 07:54 AM
Default Re: How to determine octane rating necessary for certain compression ratios? (Stumpy)
ttt
Old 06-28-2002, 09:45 PM
white's Avatar
The proper question would be , " how much more fuel" , and the difference would be minimal. The higher octane could actualy cause more of a problem if the higher compression were to cause a lean condition due to inadequate fuel delivery...tuning is everything.
[Modified by white, 6:47 AM 6/29/2002]
WarpedSportzKid
02-08-2007 01:11 PM
hondab18civic
02-06-2006 07:24 AM
crxsirvtec
09-16-2003 10:26 PM
90da4dr
03-07-2003 09:36 PM
Kev95lx
12-07-2002 12:37 PM
Quick Reply: How to determine octane rating necessary for certain compression ratios?
