How to adjust the throttle cable??
Re: How to adjust the throttle cable?? (hooptie157)
my throttle is feeling alittle loose and I want to adjust it. How do you make that adjustment?
www.helminc.com
Re: How to adjust the throttle cable?? (Flux)
You buy a Helms manual....
www.helminc.com
www.helminc.com
Yeah I was expect a remark like that but does anyone Actually know how and want to share with me??? Or is it too hard to do on your own
Be sure not to over tighten.
thanks flux I'm going out just to spec it out right now, and I didn't think you were being sarcasitic it was a reasonable answer
OK here goes-
1 you loosen the two nuts.
2 if you're facing the car, pull the cable gently toward the driver side until you hear the idle change. then loosen it until the rpms drop back.
3 once you get the cable where you want it- tighten the nuts back.
-jeff
-jeff
AtoZ
08-13-2010 10:16 AM
KimChiKid
10-08-2006 07:26 PM
VWkila
01-13-2005 06:53 PM
