Is HID ballast on JDM headlight equivalent to s2k or TSX HID ballast?
Old 11-13-2007, 10:40 AM
JDM_ITR's Avatar
Default Is HID ballast on JDM headlight equivalent to s2k or TSX HID ballast?
Here is the problem guys. My passenger side ballast went out on me on my HID JDM front end. I've had the HARDEST time trying to source the ballast for it. I called passwordjdm.com and they told me i should check the s2k or TSX ballast to see if it might be a direct fit. Can anyone confirm or post pics of their ballasts? thanks so much.
Old 11-13-2007, 11:41 AM
JDM_wanna_Be's Avatar
Default Re: Is HID ballast on JDM headlight equivalent to s2k or TSX HID ballast? (JDM_ITR)
s2k ballasts are a lot smaller than the JDM ITR ones, but i'm not sure about the TSX ballast
Old 11-13-2007, 08:29 PM
ITR#132's Avatar
Good luck, I think the ITR ballasts are unique (but I am not 100% sure)
Right/Pass. side ballast 33108-ST7-J01 (You will cringe once you find out how much that costs from Honda)
Either find one used (make sure its from the side you need) or just put the smaller ballast inside the black case.
Have you double checked the fuse under the dash?
Old 11-14-2007, 08:54 AM
sheekdude's Avatar
Default Re: Is HID ballast on JDM headlight equivalent to s2k or TSX HID ballast? (ITR#132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR#132 &raquo;</TD></TR><TR><TD CLASS="quote">Good luck, I think the ITR ballasts are unique (but I am not 100% sure)
Have you double checked the fuse under the dash?</TD></TR></TABLE>
X2. The closest thing i've ever seen to an jdm itr one is one from a 99-01 3.2 tl but i don't know about the fitment.
Old 11-15-2007, 07:50 AM
JDM_ITR's Avatar
How much is it from Honda? Finding it used is just about impossible, I've tried everywhere. I willing to use any of the listed ballast if they plug up to mine and work. I just need some sort of replacement.
Old 12-30-2007, 10:58 PM
Type-GRR's Avatar
Default Re: Is HID ballast on JDM headlight equivalent to s2k or TSX HID ballast? (sheekdude)
ITR#132 - I'm in the same predicament. Thank you for your insight. Can you elaborate on the particular fuse I should check under the dash? Thank you for your help!
Nate.
Old 12-31-2007, 05:55 PM
spoolinfool's Avatar
Those ballast are the same on both sides.They are interchangable from left to right.The bracket that holds them in place is side specific.I would buy yourself a new set of hella hid ballasts off ebay and change both.If you change one with a new oem one your still left with one that's about 8 years old.That 8 year old ballast might go out tommorrow or the next day.
Old 01-10-2008, 10:41 PM
JDM_ITR's Avatar
Default Re: Is HID ballast on JDM headlight equivalent to s2k or TSX HID ballast? (spoolinfool)
any after market HID ballast should work right?
Old 01-11-2008, 03:04 AM
sheekdude's Avatar
I'd stick with a more reputable setup like Hella or source some used OEM ones like from the tsx, tl, s2k, RL, Mdx, Rdx, etc.
Rahxephon
01-22-2006 08:08 AM
realis9
11-20-2005 01:33 AM
DC2 to AP2
04-25-2005 12:37 PM
an2ny888
12-09-2003 07:32 PM
CIVIC dude
03-01-2003 11:57 AM
Quick Reply: Is HID ballast on JDM headlight equivalent to s2k or TSX HID ballast?
