Greddy Oil Catch Can Baffled?
So with the help of a few corona's i finally got the catch can 90% installed. Damn Greddy doesnt supply enough hosing to get the job done right though. Anyways, I was wondering if the Greddy can comes baffled or do i need to stuff some steel wool in there?
Re: Greddy Oil Catch Can Baffled? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">Overpriced junk.</TD></TR></TABLE>
and its empty...
and its empty...
Re: Greddy Oil Catch Can Baffled? (98cwitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98cwitr »</TD></TR><TR><TD CLASS="quote">Que?</TD></TR></TABLE>
Fittings are right next to each other, no baffling, its too big, and its got a t00b to show you how full it is? *shrug* I dont see a petcock for easy draining either.
Moroso if you have the room, otherwise have a metal shop make you a 2x5" can with a drain on the bottom and two fittings for vacuum tube.
Moroso if you have the room, otherwise have a metal shop make you a 2x5" can with a drain on the bottom and two fittings for vacuum tube.</TD></TR></TABLE>
cusco is like that too though. and those are the only two that i could find as a kit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98cwitr »</TD></TR><TR><TD CLASS="quote">cusco is like that too though. and those are the only two that i could find as a kit </TD></TR></TABLE>
http://www.visualnoise.com/fasttimes/breather.html
Call these guys - i bought the 3x6" unit, but i am sure they could make you a smaller one.
