front and rear caliper bolt/pin torque specs? - Honda-Tech
Old 06-15-2006, 10:42 PM   #1
makibaka's Avatar
Default front and rear caliper bolt/pin torque specs?
Just finished converting to ITR brakes/suspension and am freshening up the brakes. What are the torque specs for the caliper bolts (front and rear) that have to be removed when changing out the pads? Same spec as GSR brakes?
Thanks in advance :thumbup
makibaka is offline   Reply With Quote
Old 06-15-2006, 10:52 PM   #2
Default Re: front and rear caliper bolt/pin torque specs? (makibaka)
36 ft lbs..
Joo need a manual.
Circuit Star-29 is offline   Reply With Quote
Old 06-16-2006, 10:36 AM   #3
makibaka's Avatar
Default Re: front and rear caliper bolt/pin torque specs? (Circuit Star-29)
Thanks! How about for the rear caliper bolts?
Quote:
Originally Posted by Circuit Star-29
Joo need a manual.
This is true. After owning 10 hondas (and having 6 different Factory manuals), you'd think I'd know to be better prepared when doing stuff like this I must be getting old
Old 06-16-2006, 01:23 PM   #4
pretty sure rear is the same..
http://www.hondahookup.com/manuals/ You'll need to log in to access the manuals... Enjoy.
Modified by Circuit Star-29 at 11:21 PM 6/16/2006
Old 06-16-2006, 01:38 PM   #5
makibaka's Avatar
AWESOME RESOURCE!
Thanks
change front calipers 16v Honda Civic / Del Sol (1992 - 2000) 3 11-08-2007 12:14 PM
Brake question. spindle and brakes. EJgsr Honda Civic / Del Sol (1992 - 2000) 5 01-16-2007 08:35 PM
what is the torque specs on tighten the crank pulley bolt for 1995 vtec lude ? superturboprelude Honda Prelude 2 01-08-2004 04:57 PM
h22 stock head bolt torque spec chrisir19 Honda Prelude 3 11-23-2003 05:46 PM
Changing Brake Pads, Torque Specs?? b00stn Honda Civic / Del Sol (1992 - 2000) 7 02-28-2003 09:10 PM
Tags
00, 06, 2000, 2003, bolt, bolts, caliper, civic, honda, integra, specifications, specs, thread, torc, torque, tq
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
