Factory Recommended Tire Pressure for ITR
Old 04-08-2003, 08:31 AM
EricUSC's Avatar
Default Factory Recommended Tire Pressure for ITR
What is the factory recommended tire pressure for the Integra Type R? It is in the owner's manual and also in the driver's door jam.
Old 04-08-2003, 08:46 AM
GRM Scott's Avatar
Default Re: Factory Recommended Tire Pressure for ITR (EricUSC)
It's in both the places you mention, so why do you ask? 35PSI front, 33PSI rear, cold pressure is factory recommended.
Old 04-08-2003, 09:25 AM
EricUSC's Avatar
Default Re: Factory Recommended Tire Pressure for ITR (Aleph)
Thanks! I'm asking because I don't have an ITR, but will be getting the same 195/55/15 Bridgestone Potenza RE010 tires for my Civic.
Old 04-08-2003, 09:26 AM
Flux's Avatar
But pressures will be different due to car weight etc....
Old 04-08-2003, 09:27 AM
Global Moderator
Reid's Avatar
I highly recommend using the money for two sets of Falken Azenis, rather than one set of RE010s.
Also what's your suspension setup?
I wouldn't assume that stock ITR tire pressure is optimal for your setup.
Old 04-08-2003, 09:34 AM
EricUSC's Avatar
Default Re: Factory Recommended Tire Pressure for ITR (Reid)
I have a '97 Civic EX coupe. I bought wheels which came with Potenza RE010s. I will be putting in Mugen Lowdowns. What do you guys think would be the best tire pressure with this setup? The factory recommended tire pressure for the 14 inch wheels is 30 front, 29 rear. Anybody here know the recommended tire pressure for the 99-00 Civic Si, because that car also has 15 inch wheels.
Old 04-08-2003, 09:36 AM
Boba Connoisseur
SkyeC's Avatar
I'd take them up to 35 and see how you like it.
I personally run 38psi on Azenis on the street and drop the rears down at autoxs for oversteer purposes.
Old 04-08-2003, 09:37 AM
Global Moderator
Reid's Avatar
Tire pressure from the factory is not related to wheel size.
It has more to do with handling characteristics to make the car "safe" to drive for the average idiot.
Since your car has no rear swaybar, try running more air pressure in the rear to get more rotation.
I would try 40/44.
Old 04-08-2003, 09:44 AM
EricUSC's Avatar
So that means that if my car came with 17 inch wheels from the factory, then the factory recommended tire pressure would still be 30 front/29 rear?
For now, it doesn't, but I will be adding one from a Civic Si soon.
Old 04-08-2003, 09:46 AM
Global Moderator
Reid's Avatar
Obviously, lower aspect ratio tires require more air (in most cases), but we're dealing with 50 series tires which are not low aspect ratio.
FWIW, I ran 44/50 in my RE010s on my ITR. Oversteer is fun.
Old 04-08-2003, 10:04 AM
Vampyre's Avatar
s-03's own wayyyyyyyyyyy better then the r010 and cheaper.
i have my pressure set a bit higher with the s-03's. but yeay your civic has its own pressure setting.
Old 04-08-2003, 10:06 AM
Global Moderator
Reid's Avatar
Default Re: Factory Recommended Tire Pressure for ITR (Vampyre)
What makes the S-03's so much better than the RE010's?
I was impressed that the ITR came with such good tires from the factory. It's hard to believe that S-03's are significantly better than them.
Old 04-08-2003, 11:12 AM
Chris N's Avatar
RE-010's were excellent max-grip wise in the dry, they were awesome tires. But... they sucked ***** in the rain, in any kind of rain (especially any standing water), whereas the S-03's have almost the same grip in the dry and are amazing in the rain. I just hate my 195/50's, so i'm biased to say i like the re-010's better.
I'm my '00 Si with 195/55/15's I ran 38/36. I do not remember what the recommended tire pressures were in that car with that sized tires, sorry.
benji7288
11-21-2007 01:21 PM
pnoi_01dc2r
05-28-2007 07:24 AM
TealCivic93
02-19-2005 05:04 AM
mugen92acintls
03-06-2004 02:12 PM
Quick Reply: Factory Recommended Tire Pressure for ITR
